Samsung LN52A530 LCD TV Logo
Pam McDonald Posted on Mar 11, 2014
RRght 1/3 of screen had vertical lines, now solid black.
Right one third of screen had vertical colored lines, now is solid black in front of menu screen. Replaced T-con board and no change.
Baker TV Repair
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 57 Answers
  • Posted on Apr 17, 2014
Baker TV Repair
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
57
Questions
0
Helped
7830
Points
62
That is most likely going to require a new display. what is the model, version, and serial number for the tv? I may be able to help.
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on Oct 22, 2007
SOURCE: VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
roety
Eric Rotmil
  • 587 Answers
  • Posted on Aug 19, 2009
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Anonymous
  • Posted on Feb 27, 2011
SOURCE: Multi-colored vertical lines fade in
Tab Bonding Issue. I too have had this problem with the very same model, it is most often improperly diagnosed as a t-con board issue by most who just want to provide an answer for the sake of there own ego at various forums. This is a manufacturing defect. I have been dealing with Samsung for over a month now and have been offered a replacement model of lesser quality(LN40C650L1F) at a prorated cost of $300.00 to me which I have not accepted as of yet. My TV began having this issue almost exactly 1 year beyond warranty period. Typically it will only happen when TV is cold(if temp in room falls to approx. 68 deg or lower). When cold due to naturally occurring shrinkage as with anything, the tab bonding contacts to the screen are broken and therefore gives you 3 thin horizontal lines across separating the screen into four quadrants vertically and blurry details of everything including channel info, menu info, etc. It goes away after several minutes of warm up time, as the unit warms up expansion of the panel resumes and contact through the defective tab bond is made and picture is back to normal. A quick test to determine this is if you gently squeeze the bezel(frame) around the panel at the top left corner approx. 2 to 4 inches from the corner(this is where the defective tab is located for this particular problem) the problem will go away until the unit is turned off and has ample time to cool off again. When you squeeze you are effectively forcing the tab bonding back together and contact again is made. Another way to diagnose would be to turn your thermostat in house up above 72 degrees or so and wait a few hours for the TV to acclimate to the temp(expand) .This is why if left alone for a few minutes to warm up the problem disappears. Consequently people who keep there homes on the warm side, say above 70 deg. don't often see this problem, but the more heat-cool cycles the units go through the more likely this problem will rear up its ugly head.I believe this defect will pop up eventually on all samsungs produced with the same tab bonding method or materials that were used for however long they were manufactured that way. Naturally everything moves(expands and contracts) through heat-cool cycles but proper engineering methods or materials should prevent something like this from happening for at least, lets say 10 years, the average life expectancy one would expect to get out of a $1500.00 or more purchase depending on screen size. Common sense would dictate larger screens would be more prone to this problem due to more movement and smaller less prone. Unfortunately there are numerous tab bonds all across the top of the screen(panel) and different ones affect different functions of the operation of the set, therefore there may be many other various problems people may be experiencing with there samsungs due to a failure of one of these tab bonds. They are often erroneously diagnosed as circuit board failures due to laziness on the part of the tech. I would recommend to anyone experiencing intermittent or any problems to gently squeeze all along the top of the bezel to locate a defective tab bond. As for dealing with Samsung, all I can say is good luck, it is difficult to reach their corporate office and even more difficult to get a resolution. I would gladly join in any class action lawsuit if brought about as the one regarding their capacitor issue disappeared once they sought to start addressing the issue and this was only after an absurd amount of complaints to the NJ BBB and consumer affairs websites. I think they realize that they have a huge problem with most models manufactured in the last 3-4 years(primarily due to using cheaper components as a cost reduction/profit boosting solution) and as with any large corp., are not willing to issue any recall as it is cheaper to just deal with angry customers on a case by case basis, very unfortunate for them as their sales will suffer terribly because most people research on the web before making major purchases in today,s world and thank god for that.
Chi Chu
  • 8457 Answers
  • Posted on Mar 02, 2011
SOURCE: My Samsung LN52A550 has colored vertical lines in
Yes,this problems alway the problems and the causes by the T-CON decodering board.If this problems acurring by it self.If this problems are causes by and an object or a person by hitting the LCD screen panel itself,than LCD screen is dead,not repairable.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Anonymous
  • 10594 Answers
  • Posted on Mar 28, 2011
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
4answers
There is a tiny line appearing on my philip plasma tv. please help
If you mean a black vertical line from top to bottom, then it means the TV is on its way out. This has happened to me and I lived withit until it got too wide and I had to replace it with a new one.
Samsung TV vertical lines
Hi Paul,
I am sorry. There is nothing you can do about it. It appears to be a defective panel.
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
The screen is blue with vertical dotted white moving lines ... menu options are psycodelic in color
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem, and do take care in handling the problem....
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
Hope this will help out in solving the problem....
2answers
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
Hope this will help out.....
1helpful
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
Good luck and take care in handling it ........
2answers
NTV Scree
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
Hope this help....
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
