Question about Kenmore 62702 Microwave Oven
Error code of F-3.
Hello I have a kenmore 363.62702 and it displays an error code of F-3.  Unplugged it and started over, runs for a short time then shuts down.
  • 328 Answers
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
If my attachment made it, it shows a common way to do this....
Good Luck!
Microwaves are very dangerous, they can still shock you even unplugged!! These pages are to help give you indications of what might be wrong and some safe "how to check" or repair help.
Posted on Oct 29, 2007
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
I have have a 10 year old Kenmore Hood/Microwave combo built by Whirpool. I'm getting an F6 error code. What is the error code trying to tell me?
F6 —Microwave Relay Failure: Check the microwave relay.
The F6 error code which is flashing on your microwave refers to a faulty relay. However, I would suggest that you first try to run a diagnostic (which you may not be able to, but it is beneficial if it works). Here is how:
Hope that helps.........
Jul 10, 2008 | Whirlpool Microwave Ovens
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
ERROR CODE F6 SOUNDS LIKE IT RUNNING. UNPLUGGED IT AND PLUGGED IT IN AND WHEN I SHUT THE DOOR SAME OLE
Hello lyle,
The reason your microwave comes up with the error code f6 is simply because there is a shortened key, also know as a bad relay. I bet you have a kenmore microwave oven there.
It will act like it is about to start working, sometimes, the tray would roll inside the oven, but will not work.
You need to check wiring to relay 4903 for short circuit, then correct the short circuits you seen.
Hope this helped you.
All the best.
Elect_Comp
Dec 12, 2011 | Microwave Ovens
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Error Code F-3
An F-3 is a bad temp sensor and needs to be replaced
Oct 29, 2007 | Kenmore 62702 Microwave Oven
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Kenmore 62702 Microwave Oven Logo
142 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
