Question about Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8440D
We're able to receive faxes but not able to send top tray not working it seems that rollers not grabbing item to send. Please advise. My e-mail address is
Thank you
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 29 Answers
I have the hindge in stock for 23.00 includes shipping. pay by paypal to xeroxservice attach your mailing address. NO PObox
Posted on Mar 01, 2014
Thank You Soulvisitor to Link for Hinge! Google did not work for this link... You are a Guru. Thanks again.
Posted on Feb 19, 2008
  • Brother Master
  • 1,113 Answers
Left hinge is broken, stopping doc cover from being seen as closed by machine. ie black switch in corner is staying open when lid is closed
Replace hinge (20bucks, brother dealer)
Posted on Dec 16, 2007
Thank you for your reply but the two available solutions did not work. I can copy and also receive faxes. I can fax one page but am unable to fax multiple copies. The rollers don't engage. The machine immediately dials w/o trying to scan.
Posted on Dec 14, 2007
  • frogger13 Dec 17, 2007
    Thank you Soul Visiter,
    This gives me aplace to start looking. I verified that the cover was not going down all the way preventing the swith from being tripped. However, when I hold the cover down I seem to still have the problem. I will have to work with it a bit.
    Thanks again.
My guess is that you are experiencing what I ran into with my 8640D recently. It isn't the feed at all, it is the scanner that isn't working. Try to lay a paper on the glass and see if it will copy. If it doesn't do anything... the problem is the scanner doesn't work. The scanner not working turned my MFC-8640D into an over sized printer that could receive faxes. The scanner is used in faxing out, copying and scanning of course.
What happens is without the scanner working, the feed doesn't feed the document since it can sense the scanner isn't doing what it should be doing. Someone replied to me that it could be the PCB... so I need to research what the PCB is, how much it costs and if I can even get one.
I also bought a new Brother MFC since it is vital to have a machine that works.
Posted on Nov 02, 2007
  • 121 Answers
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Posted on Oct 30, 2007
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
MFC 8300 Laser Printer: do i receive anything after i send a fax?...
Only if you have set the fax options to automatically print a sent item/transmission report. Otherwiase you will receive nothing unless the person or company you sent a fax to decides to fax you back.
May 06, 2010 | Brother MFC 8300 Laser Printer
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 9600 won't pull paper from tray
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Brother MFC 9600 All-In-One Laser Printer
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
MFC 440CN fax machine
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Jan 08, 2008 | Brother MultiFunction Center MFC-440CN...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8840D All-In-One Laser Printer Logo
397 people viewed this question
James Cagle
James Cagle
Jim Keysor
