Question about SanDisk Sansa e260 MP3 Player
Insufficient memory I've erased all the songs from my device but I'm showing that I have only 1GB of space available. I've checked all folders and all are empty. What do I need to do to make the remaining 3GB available for downloads? Thanks!
  • emotionalgrl Nov 13, 2007
    i hav the same problem and the recovery mode doesnt do anything
  • Anonymous Jan 04, 2008
    will not read on the computer
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 31, 2007
BLU Advance 5.0 Android phone won't let me add apps as there is "insufficient space." File Explorer says phone storage is 99% full but shows few files anywhere in the folders
1) go to Settings, and under Device, click Storage, then click Transfer data to SD Card.
2) go to Settings, and under Device, click Apps, then for every app : click on the app name, then on storage, then on Clear the cache.
3) If you don't want to repeat this cumbersome process manually from time to time, many apps can do it for you. I personnaly use one called AppMgr III, installable from Google Play.
Apr 17, 2017 | Blu Cell Phones
Memory capacity
Yes it should. I would remove all of the contents on card and save them then reformat the card and check to see if the full space is available. If not there is freeware available to restore these things to correct amount. If it cannot be done then the card has an issue and needs to be replaced.
Sep 06, 2017 | Samsung YP-U1 MP3 Player
I cannot access the navigation on the sylvania gps.what is says is it "not enough storage space start application,make sure you have at least 5MB available.can you please heilp me.thanks
Its obvious from the problem you are experiencing with your GPS device that,the memory space available on your device is not enough to effectively run the navigating application on your sylvania,hence its requesting for sufficient memory,
This might be as a result of the fact that the device is either corrupted by a virus,or it's memory is insufficient for the navigation application,
The solution goes as follows;
1.Insert an external memory card of the right specification(at least 1GB) into the memory slot provided.
2.If the problem persists,then you should perform a hard reset on your device,which is clearly described in your user manual.afterwards the problem will be solved.
Thanks and take care
Dec 02, 2010 | Sylvania GPS
I have a toshiba 2.0GB thumb drive with nothing on it and when i go to get info it shows only 983 KB available!
Your computer may be reserving space on the drive and using it to speed up your memory of your computer. Some have default settings that automatically do this. Try reformating the portable drive to erase the contents and settings and see if this recovers your available space.
Sep 27, 2010 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I'm using a 1gb sandisk sd memory card to sync mp3 song on it. THe mp3 songs go on it fine and play on the computer and on the mp3 player ok. The problem is I have about 533mb of space used and have about...
You may have reached the maximum number of files allowed in the root directory of the file system. If you already have a folder on the card, try moving some of the MP3 files into that folder. If you can copy 1 new MP3 file onto the card, that is your problem. Hopefully your MP3 player supports folders!
Oct 04, 2009 | Kingston 1GB Secure Digital Memory Card
Can't put songs onto Philips GoGear 1GB
ok when your in the mp3s folder click on tools then folder options and then the view tab look down near the bottem of whats displayed and check the box show hidden files and folders and see if there are any files being hidden on the device if not then id say get the firmware and device manager for it and reformat it just keep the firmware and device manager handy so you can restore it if anything goes wrong after the format
Sep 18, 2009 | Philips Audio Players & Recorders
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
NWZ 615F Blk MP3 player
 “I can’t load any more songs into my mp3 player” or “An incorrect number of songs show up.” (MEMORY/FORMATTING ISSUE)
Sometimes, you can’t load any more songs into your player because, well, there just isn’t any more space left on your player.  Mp3 player product documentation does not actually list the actual amount of memory that you can use in your player, and it doesn’t list the actual number of songs that you can realistically fit on your player.  Every mp3 player needs a certain amount of memory space to operate and firmware upgrades decrease this available space – so, your 2GB mp3 player actually contains only 1.7 or 1.8 GB for music and other media files.  The mp3 player that says “can hold up to 1000 songs” may only hold 400 songs – the product documentation assumes that you are loading a 1-minute song in the lowest possible quality format – not very realistic.  A single 30-minute audiobook, speaker file, or video can seriously bring this number down.
Other times, however, you are experiencing a formatting issue or memory corruption.  If you plug your mp3 player into a computer that has an NTFS file system, and then plug it into a computer that has a FAT32 file system, you may experience this formatting issue (file system/formatting issue).  Similarly, this will happen if you plug an mp3 player into a computer running Windows Vista, and then plug it into a computer running Windows XP (operating system/formatting issue).  Or, if you plug your computer into a PC, and then into a MAC (PC or system/formatting issue).  Or, if you plug it into a computer with Windows Media Player 10, and then into a computer running Windows Media Player 11 (software/formatting issue).
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders. To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution.
Before proceeding with a format or reformat of your mp3 player, check with the manufacturer first.  On many players, a format or reformat along the lines suggested here will override your mp3 player’s native formatting and render your player unusable.  Transcend’s T.Sonic player is especially susceptible to this problem, and should never be formatted.  Also, the instructions below are for Windows-based PCs, not for Macintosh.  There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in some cases by updating the player's firmware or reloading the firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
My Lyra RD1072 ... trouble with memory card
Thing is that the memory card is in a totally diffrent folder... you need to put the card into your mp3 then open both folders. download your songs... then voila extra mp3 space!! see for example my mp3 is hooked up to my E: drive but to get access to my memory card i have to open up the F: drive also!! :P
Sep 26, 2007 | RCA Lyra RD1072 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
