I have a white GE Spectra, with the classic 4 "ribbon style" burners, and the oven. lately, one of the two large burners, the one "back left" , was working either "all hot" or noting at all. I put in a new ribbon element, and the problem was still there.. tonight, out of the blue, it stopped working altogether, and it stays cold. the other 3 burners work fine, and the oven seem to work fine
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak. You can look at it and see how it compares to the broil ignitor. If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
SOURCE: GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
SOURCE: GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
SOURCE: ge spectra jbp64, replacement bottom bake element
Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
