Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Machine wont wash
After filling up with water, the machine makes a  loud grinding noise and doesn't spin.
  • 58 Answers
Re: machine wont wash
Needs a new motor coupler. small round rubber piece between the motor and transmission. easy to replace
Posted on Oct 31, 2007
0 characters
3 Points
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
My Kenmore Elite top filling washer 22952 100 spins as its filling with water and makes a loud grinding noise as it changes cycles
chances are there is a piece of broken glass in the bottom. Happened to me , found out a glass had broken and pieces were causing a grinding noise.
Jan 29, 2011 | Kenmore Washing Machines
Washing machine wont rinse or spin
it fills up with water but it won't spin and then makes like a grinding noise someone told me it could be a clutch
Aug 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills with water but will not agitate to wash the clothes.
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
