possible
right click on the publisher 8 and then click on the properties tab
then click on compatibility tab and adjust to win 10
if there is no win 10 for compatibility, you may have to upgrade the version of publisher 8 or upgrade the driver for publisher 8
Calendar Creator is not supported for Windows 8 at this time. Even the newest version which is 12 is not supported fo Windows 8. You could try running it in compatability mode however.
Right click the Icon and select "troubleshoot compatability"
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
You can try this "Make older programs run in this version of Windows" using the "Program Compatibility troubleshooter" in Win 7 -> LINK If it does not work, then you need a newer version 8.
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
