Question about Zenith C27A24T 27" TV
Power Button My Zenith C27A24T 27" TV won't turn on with the remote or with the power button on the set itself.
  • tinlizzie Oct 29, 2007
    Sorry, I put down the wrong model It should be SR3238RK
  • 50 Answers
There is a line fuse inside the set should be a 4 amp, could be blown and if it would blow again you have a short on the board. (if u r to try it don't forget to unplug tv!)
Posted on Nov 28, 2007
Need cods for a universal remot to a zenith tv
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes: Phillips Universal remote Codes-713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 OneForAll Codes- 0017 0463 0178 009 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Zenith C27A24T 27" TV
if you have remote press the tv button then video or av button this may work. i need to know the model to help you better
Jan 02, 2009 | Zenith C27A24T 27" TV
Program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
Dec 28, 2008 | Zenith C27A24T 27" TV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
How do I unlock the volume control?
Zenith Electronics Corporation is a long-time leader in electronic enterainment products.
Aug 24, 2008 | Zenith C27A24T 27" TV
Tv will not turn on after sudden power outage
you most likely blew a fuse the only "reset" is to unplug the t.v. and leave it unplugged for a few mins, then make sure that you hold down the power button to drain the power out of the t.v.then turn it back on.... only other reset sequence is for removing the parental code
Jun 24, 2008 | Zenith C27A24T 27" TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
Jan 20, 2008 | Zenith C27A24T 27" TV
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
