Question about Motorola Mobility H500 Wireless Headset
HOW DO I SET TO DEFAULT SETTINGS - Motorola Mobility H500 Wireless Headset
I want to set google as my default
Go to your Search Engine and under the name click on "preferences" - in the "General" settings, you can set the default browser as Google. Make sure you are on Google when you do this. You can also set it as your homepage on the same settings page.
Mar 11, 2015 | Google Computers & Internet
Ps3 was owned by someone else and they put a block for mature games how do you get the block off
Unless you know the password they used you would need to completely re-initialize the unit as it was a new one, from the beginning, to wipe it out completely and set it back to factory defaults (sledge-hammer reset).
There is no way I know of to retrieve this lost password if you do not also know the owner's PSN information, which I'm sure you cannot get to. You might Google the question.
Feb 14, 2015 | Sony Playstation 3 (PS3) Console
How to make Google my default browser
Hi Faramarz,
I have this simple steps on how Google chrome be as your default browser. Hope it helps.
Make Chrome your default browser If you like how Google Chrome works, make it your default browser! By doing so, future links you click will automatically open in Google Chrome. Follow these steps to set Google Chrome as your default browser:
  1. Click the Chrome menu snp_9721c573e41777fba43e1498ad084e3b160c_2696434_en_v2 on the browser toolbar.
  2. Select Settings.
  3. In the "Default browser" section, click Make Google Chrome the default browser.
Dec 19, 2012 | Google Chrome
Google chrome default fonts
I am not sure if you are on Windows or Mac, but below you can see a screenshot of the default settings on Mac.
May 04, 2012 | Google Chrome
What are the factory default settings? What will I have to redo after the factory default settings are set?
Any customized setting you changed on the receiver will go back to factory default. Here is a list of the settings that would change:
  • Favorites Lists are cleared and the titles set back to List 1 - List 4
  • Search History is cleared
  • Alternate Audio is set to English
  • Closed Captions returns to default settings
  • Mode Reminder is enabled
  • Receiver is set to Dual User Mode
  • Caller ID history is cleared
  • Phone Setup is set to Touch Tone and No Prefix
  • Audio Output: Decoder set to Dolby Digital/PCM
  • Updates are set to 3:00 AM
  • Guide text is set to Small if the receiver is connected via HDMI and Medium otherwise
  • Guide format is set to Standard - Partial Guide with Video
  • Inactivity Standby is enabled
Locks, timers, DVR and Remote Address settings are not altered
Aug 19, 2011 | DISH Network ViP722 DTV Receiver /...
GPRS Problem in my handset nokia2630, bsnl prepaid. I save message sent by bsnl. G is coming and sometimes E is coming at left of Set. When I try to connect gprs it shows subscribe packet data first. This...
hi....
think you didnt select your BSNL settings as default setting ,so only your getting as 'subscribe to packet data first'.
As you said it says 'only 20 sets are allowed', there are plenty GPRS settings present in your mobile.please go to default configuration settings and delete all the settings which you previously stored in it.
Now call your BSNL and ask them for the GPRS settings they wil send GPRS setting and MMS settings also. please save it and make it as default settings.Then you can start using the GPRS connection.
If you didnt select it as default setting,follow the below steps to set it,
please follow the steps down to set your BSNL setings as default.
Menu--->Settings---->Configuration---->Default configuration settings.
open this menu and select BSNL as your default service provider,
Then you can start using your GPRS.
Thanx
Jul 19, 2010 | Nokia Cell Phones
MY RICOH 2020D PRINTER, IS VERY SLOW AND IT DOES NOT SCANNED AT 20PPM, PLUS THE FAX MEMORY ONLY HOLDS UP 40 PAGES, WHAT CAN I DO?
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" ...is either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
How can I permanently alter the Default Print Settings?
In the control panel, you can select your printer and set defaults. You can also set them in your printer's setup & maintenance program.
Jan 31, 2009 | HP PSC 2210 All-In-One InkJet Printer
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Default settings for copier
There must be s "custom setting" set as default. Check properties and restore defaults where applicable. http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 This is an online manual for your machine. Good Luck, Tim
Feb 06, 2007 | Canon Pixma MP500 All-In-One InkJet...
Motorola Mobility H500 Wireless Headset Logo
53 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
