Question about HP Compaq Presario 730US Notebook
System failure in my laptop ??
Hello, i am living in germany , i bought a laptop from , it is sealed and not used (COMPAQ 730US) ,, when i recive it , i found that the end plug of the charger not the same one used in germany .. so i charge it with my other laptop charger just for two hours till i went to buy a wire with and ending plug like the one used in germany , its also hp pavillion dv6000 , the next day i want to turn the Compaq on , there was not any response, the button turned blue for a second and suddenly off...
my hp dv6000 charger is : INPUT     100-240V , 1,5 A , 50-60 HZ
                                      OUT PUT 19 V - 4,74 A
                                        90 W
my compaq charger is :   INPUT    100-240 V , 1,6 A , 50-60 Hz
                                     out put : 18.5 v , 3,5 A
                                       65 W
kindly help me , because itsrealy sad a computer last 24 hours ??
my email is
thank u so much
  • 78 Answers
Re: system failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Posted on Oct 29, 2007
0 characters
3 Points
Compaq 730us touch pad not responding
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 06, 2011 | HP Compaq Presario 730US Notebook
Wireless not working compaq 730us
First thought check for the wireless switch. It is normally located on side of the laptop, some models have this button above the keyboard. Make sure it is turned on. You can normally tell if it is by the color of the light by the switch. Blue = on, Red = off.
If this is not the case answer the following question to help narrow the search:
1. Has the computer connected to this network before?
2. Can the computer connect to anyother network (e.i. at a friends house)
3. Were any updates install?
I hope this helps.
Jul 22, 2011 | HP Compaq Presario 730US Notebook
My toshiba 730US laptop has been overheating and shutting down I was going to trash it, but found out I could clean out the heat sink to solve the problem. I cannot find a manual to dissasemble the...
Here is the link to manuals available for your HP 730US laptop:
To avoid laptop overheating, follow also the information from this link.
Dec 27, 2010 | HP Compaq Presario 730US Notebook
Hello, I just bought a used CQ61-420US laptop off of Ebay and I would like to know how you reset the start-up login password
I assume you already have the password to access the machine. Go to the control panel, user accounts, change password (assuming Windows Vista) very similar in all windows Operating systems.
Dec 15, 2010 | Compaq PC Laptops
How dead is the hard drive. will it boot up sometimes or it never boots? Does it make any noises or it runs as normal? If it let's you boot sometime but wont let you use it for long enough to get your data the solution i would try would be any Linux live CD. Download Ubuntu bootable CD and boot from that. Try and access your hard drive then. See what you get. If your hard drive is really dead though there's nothing you can do yourself you need to get it some specialized service where they can recover HD's like this. Good luck
Apr 16, 2010 | HP Compaq Presario 730US Notebook
Compaq presario cq50-100em wont start up
I'm sorry to say this sounds like a system board failure. On my HP DV200t, a very similiar issue occured, eventually only the led where you plug in the power cord would turn blue. I replaced the system board and all the issues went away.
Hope this helps, and I am sorry to be the bearer of bad news.
Aug 31, 2009 | HP Compaq Presario 730US Notebook
Can i restore a compaq armada 1952DMT without the disc?
Hi guy1121,
since this type of laptop is a very old one you should think about installing a Linux-system on it.
In case you're still having a genuine and unused MS Windows 98-setup disc you could also try to use that one to install and use your laptop with. In that case you should check before whether HP (they bought Compaq some years ago) is still providing drivers for the laptop and for its use with Windows 98 (which is not very likely).
Good luck and greetings from Germany,
Feb 25, 2009 | Compaq Armada 1592DMT Notebook
Compaq presario 730us won't power on
Sounds like the power converter that is probably on the motherboard, so you may be looking at a new motherboard. Hard to tell without seeing it in person, but you can take it some place locally and they can troubleshoot power issues for you. GL!
Feb 07, 2009 | HP Compaq Presario 730US Notebook
Clearing bios pasword on my compaq presario
compaq and hp bios password are easy to clear. all you have to do is unplug your laptop, remove all batteries, then you must open your laptop and locate the cmos battery and unplug it for about 3-5 seconds. then put it back together.
Dec 07, 2008 | HP Compaq Presario 730US Notebook
HP Compaq Presario 730US Notebook Logo
115 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
