Question about Casio Exilim Zoom EX-Z700 Digital Camera
Meun resetting Every time I turn the camera on I have to reset all the items, just as if the camera was new.  I have updated to the latest firmware but it didn't help.  Any suggestions?
  • gauravmudgil Oct 21, 2008
    Everytime i switch on the damn thing, i have to re enter the entire information as if it was a brand new camera
I finally sent it back to the factory for repair. They had to replace the circuit board.
Thanks for the suggests I've received.
Posted on Sep 15, 2008
RESET ALL Button
I'm convinced you already did read the user manual. There are three things you can reset:
1. User settings. In menu mode P, you can undo all the settings you made. Page 69.
2. Reset all settings. Page 151 Menu settings, chose the wrench symbol and chose reset all. All settings will be restored to factory settings.
3. Reset file numbering. Page 154 Menu settings, chose the wrench symbol and chose reset file numbering.
In the same menu is also the view firmware version. Yours should read Coolpix P90 Ver.X.X .
The latest update of firmware for the P90 is 1.1 Great chance your camera came with that revision already. If you registered your camera with Nikon, they will inform you when a new firmware is released.
Really, there is nothing more you can reset on the camera.
So if something is wrong, it can't be helped with the reset you have in mind, because that reset does not exist.
If you want the firmware 1.1, goto Nikon USA and support. Everything you want is there.
Nov 29, 2013 | Nikon COOLPIX P90 Digital Camera
I have error code e106 on my 733 hp camera,whatis that?
CausesThese errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lensor
  • the lens is loose or completely off the track
SolutionFollow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera.Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately.
Nov 21, 2011 | HP Cameras
IT WON'T TURN ON, I'VE CHANGED THE BATTERIES FOR NEW ONES AND STILL NOTHING
I've had problems with my camera too but it actually started with random crashing then turned worse that I had to take the batteries off just to turn it off or i couldn't even turn it on for some reason. i also considered updating the firmware but I found out that mine actually came with the latest firmware which is 1.04. I still tried it but before doing the upgrade I decided to reset the camera and then format the memory card then followed the instructions on the website, but after everything it just said the upgrade was not successful so i just turned it off. I turned it back on again and it seems to work fine now, no more freezing or random crashing. I sure wish that fixed it. Try reseting your camera then choose the format option. Best of luck!
Nov 30, 2010 | FUJIFILM FinePix S1600 Digital Camera
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
Just the blue ring, screen does not turn on
Blue ring faillure could be solved, trying to reset the e250.
How to reset:
Only if the reset action above did not help,
reload and update to the latest firmware.
Installing firmware will erase all data from the player !
  • Step 1: Switch to MSC mode.
How to switch to MSC mode:
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
  • Step 2: Update to the latest firmware.
See next site for how to update the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Follow the information in the link.
The easiest way would be using the automatic Sansa Firmware Updater. Directly to the download Sansa Firmware Updater .
Need more help ? Just post a comment.
Dec 19, 2009 | SanDisk Sansa e250 MP3 Player
This is a brand new item , less than 70 days old. When I turn it on appears on the screen a message code firmware, clean up. And does not let me do anything else
try updating the firmware goto this site and find the latest firmware and flashing utility, support.creative.com/, then reflash the firmware using the flash tool. note this will reset the player to factory defaults so if theres anything on it you want to save get it off there first
Sep 29, 2009 | Creative Labs ZEN SLEEK MP3 Player
MY Phillips mp3 player is frozen.It doesn't turn on.
Reset the player.
If it freezes again after you reset it, you need to update the firmware on your player. In order to update the firmware, you will need to get the latest version of the Philips Device Manager for your model from Philips website. Then use the "Update" function in the new Device Manager.
-Tha Mp3 Doctor
Mar 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • foreign material is inside the lens or
Solution Follow all of the steps listed below.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 | Cameras
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
