Camping, Backpacking & Hiking Logo
A
Anonymous Posted on Mar 10, 2014
My duracell 500 will not work on high
As soon as you switch high beam on it goes off
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 14, 2008
SOURCE: Headlights, high beams
No as a rule they don't fail at the same time, in fact it is unusual for the hi beam to fail ever, the problem is most likely in the turn signal/multifunction switch, this does cause your problem, have seen it many times.
Anonymous
  • Posted on Oct 24, 2008
SOURCE: Honda Accord 1994 LX DRL not working
check the fuses under the hood or relays for ur headlights
Anonymous
  • 75 Answers
  • Posted on Dec 22, 2008
SOURCE: high beam
replace the switc and also ck the hi beam relay
Anonymous
  • 130 Answers
  • Posted on Feb 10, 2009
SOURCE: high beam problem
no your highbeam switch has gone bad
Anonymous
  • 150 Answers
  • Posted on Feb 13, 2009
SOURCE: 1991 camaro switch for you low and high beams
There is a metal rod that runs down the side of steering colmn and pushes on the dimmer switch. The dimmer switch is on the steering column to the left of the steering wheel. You will have to unbolt the column where it connects to the dash and rest it (the steering wheel) on the driver seat to get to the switch.. The switch is adjustable, just loosen the screws and slide it up or down to get proper adjustment.. Hope this helps.
What can be the problem with my Kia Sportage 2013 high beam, left one works fine but right one comes on and then switches off. Earth is good so are the globes.
So when the car is off and you have your headlights switched on both the low beam setting and high beam setting work normally. But once you start your car your low beam headlights work but when you switch to your high beams the right headlight shuts off? I don't know how that'd be possible since the controls for your high beam and low beams aren't connected to whether the engine is running I'd suggest changing your headlight bulbs
Why don't my low beam lights come on? they work intermittently.
the low beam lights are switched by the stalk. power goes in the stalk and you switch it between the high beam and low beam from that. If it works intermittently it could be bad contacts in the light switch/stalk. Jon
1helpful
DASH LIGHT FOR HIGH BEAM STUCK ON EVEN WITH CAR OFF?
Looks like the dimmer switch is built into the combo turn signal wiper switch on the column.
I would unplug that switch and see if the indicator light goes off.
If it does the problem may be inside the combo switch.
1helpful
2answers
Headlight problems
If the lights work when moving or holding the high beam switch there is a good possibility the switch itself is bad. The switch is located at the base of the steering collumn. the handle actually only operates a rod that goes into the switch to push it down to switch from high to low beam. The switch is not expensive and easily accessable although you sorta have to stand on your head to reach it.
1helpful
This is about the tw 200 high beam, new bulb still doesn't seem to have any current to the yellow wires. One goes to high beam indicater, which by the way that bulb is burned out, the other goes to high...
If you have low beam then you have power to your handle bar switch, and if you have no power coming from the yellow wire from the handle bar switch,replace it.
84 honda shadow 700 vt lights are unpredictable
There seems to be some short in the circuit of the high beam, you will have to follow the high beam wiring, best would be to get the color of the high beam wire frm the head light bulb socket and trace it along you will sure find somwhere the along it the short.
Check the light switch and the blinker switch too.
Hope this helps!
Top Duracell Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Duracell Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
