Question about Nintendo Wii Console
Wii remote right i formated my wii cleared everything but then i had a power cut and it goes on to this press A to continue but my wii remote is not connecting to the wii
  • Anonymous Dec 25, 2007
    I just got my Wii, and everything works up to a point. I get to this screen that says to press A, but when I do, nothing happens, and advice?
    Guru:
  • 155 Answers
You need to resync your remote(s) to your wii. When you have turned your wii on press the red sync button next to the SD card slot then press the sync buttons on remote(s) under the battery cover. They should then both be connected. You can then change which one is no.1 or 2 etc. by pressing the home button and going into remote connection or whatever it is at the bottom and clicking on reconnect. Hope this helps. :-)
Posted on Dec 21, 2007
Wii nintendo bought used how do i reset it
Method One: The Soft Reset The soft reset is the easiest way to reset the Wii, and the least intrusive. There are two ways to perform the soft reset, either using the Wii remote or the button on the console.
To reset the Wii using the Wii remote, begin by pressing the home button (the small button with a house on it). This will bring up a menu screen. Next, move the cursor to the button labeled "Reset" on the screen. Press the "A" button on the remote to select the reset option. This will reset the system.
If the Wii remote is not responding, users can also reset the Wii using the button on the main console. First, locate the button labeled "Reset"--it's on the front of the console, beneath the "Power" button. Press and hold the "Reset" button for two seconds, then release the button. This should reset the system. Users should remember that resetting the Wii will shut down any running programs immediately and destroy any unsaved data, so only reset the Wii if it is causing problems. However, resetting the Wii will not alter any information stored on SD cards.
Method Two: The Hard Reset If the soft reset doesn't fix the Wii, users can also perform what's known as a "hard reset." A hard reset involves disconnecting the Wii's power supply and must be done manually--there are no pre-programmed buttons on the Wii that will perform the hard reset.
To begin the hard reset, find the "Reset" button on the front of the console. Press it for two seconds, then release (this performs a soft reset on the device). Next, press and hold the "Power" button. Continue holding this button until the light in the button switches from green to red--this means that the Wii console has shut down. Now, unplug the AC power adapter cord from the wall outlet or surge protector as well as from the console itself. Allow the Wii to remain like this for five minutes.
Once five minutes have passed, plug the AC power adapter cord back into the console, then connect the other end of the cord to an AC outlet. Press the "Power" button to turn the Wii on. The system should now be running smoothly.
Method Three: Reset Factory Controls Sometimes, Wii users might want to return the system to its original, factory-shipped status and remove any personal data. Nintendo especially recommends doing this before selling or gifting a used Wii to someone else. To perform a factory reset, also known as formatting the system memory, go to the Wii menu and select the "Wii" button, then select "Wii settings." Click on the blue arrow on the right-hand side--this will bring users to a page called "Wii System Settings 3." Select the option labeled "Format Wii System Memory," entering the parental controls PIN if requested. Finally, select "Format" to complete the factory reset. This will remove all hard-drive data from the Wii, and such data cannot be recovered, so users should only perform a factory reset if they're sure they want to do so.
Jan 30, 2017 | Nintendo Video Game Consoles & Games
How can i connect my wii thru my wireless?
  • instructions on how to connect wii thru your wireless
    Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2
    Press the "A" button on your Wii controller to continue from the warning screen.
  • 3
    Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4
    Click the "Wii Settings" box on the right.
  • 5
    Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6
    Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7
    Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Dec 06, 2011 | Nintendo Wii Console
    Connect to web
    1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
    2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
    3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
    4. Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    5. Click on "Wireless Connection" and then "Search for an Access Point."
    6. Select "OK" and the Wii will display all the wireless networks it finds.
    7. Select the wireless network that is yours.
    PCHELPSTER007 from youtube
    Jul 29, 2011 | Nintendo Wii Console
    How do i conect my wii to my internet
    To connect your Wii to the internet:
    2. Select "Wii Settings" to access the "Wii System Settings" menu.
    4. Select "Connection 1: None" (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    8. Select "OK," "Save Settings," and then "Yes." As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    Mar 31, 2011 | Nintendo Wii Console
    I cannot get my Wii to connect to the wireless internet. I want to set the Wii so I can get Netflix. Can you help me?
    Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None" (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours. Select "OK," "Save Settings," and then "Yes." The Wii console will run a connection test with your wireless network and you should be connected
    Jan 29, 2011 | Nintendo Video Game Consoles & Games
    I put new batteries in, all four light flash four times and then it shuts down.I pushed the little red button next to the batteries and all four lights flash fout times and then shut down. Can this be...
    What shuts down? The Wii Remote?
    If so, sounds like they need to be synced to the Wii. When the controller looks for a connection and doesn't find it, they will shut down to save battery life.
    You need to turn on the Wii with the Wii Remote [press power button on the Wii remote that is working] then click into the Wii Menu by clicking the HOME button on the Wii remote. You will then click to Wii Remote Settings. From there, click RECONNECT on the Connection menu. That will instruct you to press 1 & 2 on each remote to sync them.
    For more information, click to the following NINTENDO website which tells you everything you need to know that you've asked:
    http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp
    May 15, 2010 | Nintendo Wii Console
    Wii remote won't work. Just lights up
    pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
    Feb 25, 2008 | Nintendo Wii Console
    2nd wii remote will not connect with mario play 8
    We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
    This is from www.nintendo.com/wii :
    Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
    http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    Dec 23, 2007 | Nintendo Wii Console
    Wii remote not connecting
    Sorry this took some time.....
    You need to resync your remotes to your wii. When you have turned your wii on press the red sync button next to the SD card slot then press the sync buttons on both remotes under the battery cover. They should then both be connected. You can then change which one is no.1 and 2 by pressing the home button and going into remote connection or whatever it is at the bottom and clicking on reconnect. Hope this helps. :-)
    Oct 29, 2007 | Nintendo Wii Console
    Nintendo wii not powering on and remote blinking
    Just talked with Nintendo about this matter. Fortunately, the Wii has a safety feature on the AC adapter which shuts it down should there be any sort of significant "spike" or interruption with the power. The solution? Unplug the AC adapter for about 2 minutes (from the wall and the Wii unit itself), then plug everything back in! Believe it or not, this actually works!
    Sep 16, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    77 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
