The eMachines 5210 Desktop PC uses Integrated Graphics.
(UK model)
This means the graphics chipset is soldered directly to the motherboard.
(Also means graphics borrows some of the system resources.
Processor and Ram Memory)
It isn't a graphics card. The full term is graphics adapter card.
Here is the motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket478/msi7003.shtml
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_CircuitThe chipset, or I.C. for graphics, is the G.P.U.,
http://en.wikipedia.org/wiki/GPUThe GPU soldered directly to your motherboard, (With a BGA surface mount), is an ATI Radeon 9100,
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R200_.288xxx.2C_9xxx.29_series Integrated Graphics is also known as OnBoard Graphics.
ON the motherBOARD ]
The graphics expansion slot you have on your motherboard,
is a PCI slot.
Looking back at the photo of the motherboard, look at the three White long slots, at the bottom/left of the motherboard.
All three are PCI slots.
(They are Not PCI-Express x16 slots )
You can use any available open PCI slot.
Things you need to know when purchasing a graphics card, for a desktop computer;
1) What is the maximum rated Wattage of the Power Supply?
The Power Supply has to provide power for the computer, AND graphics card.
Look at the power requirements of the graphics card, and compare to what your Power Supply's maximum rated Wattage, is.
For the eMchines 5210 I have no idea. It is an old UK model, and eMachines doesn't support it anymore. There seems to be no info on the internet, also.
If I were to hazard a guess, I would guess 200 to 250 Watts.
However, back in the day, when the power supply manufacturer made that Power Supply, they overrated it's maximum rated Wattage.
Sold more power supply's, by 'fudging' the real maximum rated Wattage.
Correct maximum Wattage is more like 60 to 70 percent, of what is stated.
For a 200 Watt unit that would be 120 Watts to 140 Watts.
[ Divide 200 by 10. = 20
Multiply 20 times 6. = 120. That is 60 percent.
Multiply 20 times 7. = 140. That is 70 percent ]
250 Watt unit?
60 percent is 150 Watts.
70 percent is 175 Watts.
Computer unplugged from power, FOLLOW Anti-Static Precautions.
Open the computer case, and look at the side, or bottom of the Power Supply, at it's label.
This should state what the maximum rated Wattage is.
Not there?
Then the 4 Philips head screws need to be removed from the back, and Power Supply partially slid out. The label is on top.
http://www.fonerbooks.com/r_power.htmYou shouldn't have to remove any power cables. Just slide the Power Supply out, and down a little bit.
If it is 150 Watt, S-T-O-P. You will need a better Power Supply.
It is an ATX form factor Power Supply. One that is used in a LOT of desktop computers. Means it is readily available, and economical.
(No slam intended, but from what I see on UK prices, OUCH!
See if you can buy one from the USA. A decent 300 Watt unit is about $35 to $40. Decent means RELIABLE )
[ Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case. This action will relieve your body of Static.
Should you leave your computer in the middle of working on it,
be SURE to Touch the metal frame again upon your return.
This way your computer is safe ]
2) You need to know what graphics expansion slot, is available on the motherboard.
It is a PCI slot,
http://en.wikipedia.org/wiki/PCI_local_busFind a PCI slot that is open. If it is next to an expansion adapter card that is already in there, (Ethernet Card?), see if you can move over to another PCI slot away from it.
You need room for the graphics card.
Look at the metal covers at the back of the computer case.
These covers are called Expansion Slot Covers.
Find the one you need to remove, in order to install a graphics card.
(Most of the time it is not a straight shot. The expansion slot cover is one over, from the actual PCI slot you want to use)
When you buy your graphics card, it will come with an Installation Disk.
(CD)
Turn your computer on, let Windows 7 load. Then put the Installation Disk in your CD/DVD drive.
Follow the instructions. Load ALL of the software.
If it asks you do you want to restart the computer - NO!
Close all windows, go back to the desktop screen.
Turn the computer off normally.
Now unplug the computer from power. Remove all cables. (If you are not exactly sure of where they plug in, this is a good time to make notes, and a drawing before you unplug them)
You can lay the computer on it's side. Easier to install a graphics card that way.
Follow Anti-Static Precautions, and physically install the graphics card.
Make sure you plug your monitor into the graphics card this time, and not into the I/O area on the back of the computer, as it was before.
(Input/Output area. This area connects directly to the motherboard.
It is for Input and Output devices, such as the Mouse, Keyboard, Monitor, Audio, { Sound}, etc.)
Close the computer case. Plug all cables back into the computer.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
Go to the 'control panel' for the graphics card, and set the screen resolution.
Prepare to smile your face off.
By the way, want to use dual monitors? I can guide you in doing this.
Recommendations for a graphics card?
Hmmm,...not knowing what the maximum rated Wattage, your Power Supply has, makes it tough.
I'll give it a go, however.
Bear in mind, that it needs to support Direct X 11 for Windows 7.
1)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1416091&CatId=1603Does require a Power Supply with a minimum of 300 Watts, however.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147662&CatId=1077From what I read through the years, Tigerdirect ships to the UK.
For additional questions please post in a Comment.
Regards,
joecoolvette
