Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
A
Anonymous Posted on Mar 10, 2014
Kernels wont pop compleatly - Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Marks concession repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 76 Answers
  • Posted on Mar 12, 2016
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
76
Questions
0
Helped
40700
Points
112
The kettle temp is not getting hot enough so your seeds dry out and have no moisture left to pop. Very stale corn seed will give you similar results.
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
I purchased the stir crazy model 82306 and it does not pop the corn properly. Less than half of it pops. I have never had this problem with other West Bend stir crazy poppers in the past. On 4 separate...
I have one of these poppers and have been impressed with the minimal number of unpopped kernels.
On only one occassion have I not been satisfied and suspect it was due to insufficient oil being added.
Make sure you are adding sufficient oil to aid heat transfer to the kernels.
1helpful
ALL THE KERNELS ARE NOT POPPING
There are several possible culprits for your Kernel Caper.
1) You may need to add a little more oil to the kettle. Let it come to full heat--just as soon as the oil starts to smoke.
2) The corn you are using must be reasonable fresh and have sufficient moisture to pop the kernel. You can try putting 1 tsp/1 lb of corn in a ziploc bag or screw top bottle. Leave for 24 to 48 hrs to let the corn absorb the moisture.
3) Finally, due to the small size of the popping kettle some kernels will be thrown from the kettle from other kernels popping open.
This is a great little popper. You might have some luck decreasing the size of your batch--reduce your oil and corn by 1/4 each.
Good Luck
47helpful
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
3helpful
2answers
How much oil and popcorn do you need in the popper
single layer of popcorn on bottom of entire maker...no oil is needed but you can use a tablespoon if you like...butter melts through the hokes in lid....Place butter pats over top holes in lid before popping starts if you want butter to drip down on the corn ( it does pop better with a little oil!)
Kernal 1.24 wont load on my r4ds card
Don't bother with Kernel v1.24 i use kernel v1.18 downlad from http://www.r4ds.cn/download/r4ds.html and click on the "R4 V1.18 kernel (English/French/Korean)" un compress with Winrar and put on SD/TF card (delete any previous kernels you may have.
Will also need the "Moonshell 1.71 for R4" on same page as kernel v1.18 just scroll down a little lower.
Get a free account on romulation.net and download whatever games you want
Happy playing.
5helpful
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
9helpful
4answers
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Top Gold Medal Kitchen Appliances - Others Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
john h
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
