Question about Honeywell CT3600 7 Day Electronic Programmable Thermostat Heater
EEE error message
I just replaced the batteries on my Honeywell CT3600 thermostat, and when I popped the face back on the wall, an "EEE" error message is all that appears on the display.  Anyone know what I can do?
  • 1 more comment
  • Anonymous Mar 29, 2008
    Mine's showing the same message after running for a day or so with fresh batteries. Replacing the new batteries with different ones hasn't helped the situation. The only thing I can get to run is the fan; no heat, no AC, no programming capacity.
    It's 34 degrees outside, so I'm eager to get this problem solved!
    There must be a manual on the www somewhere...will start digging before my fingers freeze!
  • JIM PED Jul 08, 2008
    WHEN I REPLACED THE BATTERIES
    I GOT THE MESSAGE EEE. ANY SUGGESTIONS
  • Anonymous Sep 27, 2008
    Notice EEE on thermostat
    Fresh Batteries but no change
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Posted on Oct 11, 2008
How do I replace the battery in my Honeywell chronotherm III thermostat?
Pull the face plate evenly all the way around, it just snaps off the back plate screwed to the wall batteries are visible .
Dec 21, 2017 | Honeywell Computers & Internet
I need to clear the program in my Honeywell model # CT3600A4
OWNER?S GUIDE
Honeywell CT3600/CT3697
PROGRAMMABLE THERMOSTAT
9k=
Dec 26, 2014 | Heating & Cooling
Clear out all setting?
There should be a teeny tiny hole in the face of the thermostat for a paper clip to be inserted for clearing all programmed data and taking it back to the factory parameter settings. If not on the face, it should be on the circuit board and may even be a micro-switch.
Dec 26, 2014 | Honeywell CT3600 7 Day Electronic...
What does it mean when the battery error message stay on.replaced batteries, should. I purchase a new thermostat
No friend,
Inside the Honeywell box WILL be a battery. which is there to keep your settings if a Power Failure occurs.
All you have to do is change it and reset your Control.
A typical change of battery is explained here.
http://homeguides.sfgate.com/change-wall-thermostat-battery-25307.html
Sep 13, 2014 | Honeywell Programmable Thermostat Heater
Manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Oct 09, 2012 | Honeywell CT3600 7 Day Electronic...
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
I replaced the batteries after seeing a display of "EEE" and since then I get no display whatsoever. Honeywell/36
The internal sensor could be bad, try replacing the batteries again, be certain the polarity is correct, the sensor is inherent to the stat and the stat must be replaced.
Jul 19, 2009 | Honeywell Programmable Thermostat Heater
Screen gone blank. is there a battery to replace?
There is no battery, but I have one as well and it also goes blank. When that happens, you pull the front bezel off of the back mounted plate carefully and put it back on by attaching the 2 tabs at the top, then swing the bottom back towards the plate until the 8 pins go into the connector on the removable bezel. When you first pull it off, do it slowly and pull from the lower sides straight out.
I think what is happening is the pins get corroded and lose contact with the removable front.
Hope this helps you out.
Apr 28, 2009 | Honeywell CT3600 7 Day Electronic...
I have a programmable thermostat. The LED reads Replace batteries. The face plate has fan switch, a system switch, two arrow keys that are separated by three little function (set, hold, and run). HELP!!...
There is a base plate that is screwed to the wall. The face of the thermostat should come off from the base. Usually the batteries can be found back there. Some times a little tug will get it off the wall. Other models have small plastic release clasps that when pushed in will allow the unit to come off.
Jun 30, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
1,322 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
