Does not turn on, no lights, no power
I am sure you tried the obvious (circuit breaker on)...but have you tried resetting the motherboard cpu. Sometimes a simple power off at fuse box...wait 1 minute and then power on can reset it. If this fails, the internal fuse has probably failed. If you are brave, open the inside of the door and access the board. Inspect for failed (cartridge) fuse and for any obvious signs of a burned component in the power-feed area. (PLEASE be sure that the power is removed from the dishwasher before attempting this!) If nothing obvious is found, call the LG service folks, tell them the problem and ask for a fix or a service technician recommendation. Depending on the age of the unit, it may be repaired under warranty.
Jim
