in canada? with DRL?
is the charge (battery Light on running)
nice photo but do name all lights, i see idle is at 800rpm good.
i see check engine light there, top left. so you need to scan PCM
using any scan tool
that is first.
DRL can shut down for other failures one is charge lamp. on.
if charge lamp is on , do not drive far, or it will stall and battery will discharge and be stranded. (till AAA auto tow is called <jumped)
probally be a good idea to have a local shop run a fuel system check to eliminate alot of wasted time or money. its well worth the time to have it properly checked by a trained mechanic. alot of engine problems the computer picks up wont be noticed at first and can lead to expensive repairs
It Could Be The DashBoard Switch Itself Or The Light Sensor which is located Near The Bottom Of Your WindshieldOn the dashboard near your GloveBox may be blocked.There are no fuses for this as it runs directly off your Body Control Module which controls all your dash displays and interior lights.
1998 Chevrolet Blazer S-Series Stereo Wiring
Constant 12V+
Orange
Switched 12V+
Yellow
Ground
Black
Illumination
Gray
Dimmer
Brown
Antenna
Right Front
Front Speakers
6 1/2" Doors
Left Front (+)
Tan
Left Front (-)
Gray
Right Front (+)
Light Green
Right Front (-)
Dark Green
Rear Speakers
6 1/2" Rear Doors
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
