HP ENVY Phoenix 810-130qe Desktop with 4th Gen. IntelCore i7-4770 - 3.4 GHz, 8MB Shared Cache; 8GB DDR3-1600M- 2 DIMM ; 2TB 7200 RPM SATA Hard Drive; Windows 8.1 64; Logo
Posted on Mar 11, 2014
How can I get the lights on the HP 810-130qe to flash?
I want to make the red lights on the HP 810-130qe flash. It would look cool.
David Wheeldon
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 11, 2014
David Wheeldon
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
4892
Points
74
Hi sorry not to familiar with that but if you dont have a manual heres a free one you can try HP ENVY Phoenix 810 130qe Manual
hope this is of use
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Both red warning lights on the projector are blinking.
how about the fan does it works, then clean the filter.
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
5helpful
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
HP 4L stopped printing. Red light flashes
May be some ilegal process, May be paper not in tray, find it
1helpful
2answers
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
