Clean it. You probably have a large dust collection in, under and on your units underbelly.
You should have a collection pan, underneith, that collects the runoff water and the heat from the componits will evaporate it before it fills too much.
You could also have a leak in the plumbing system that supplys your ice maker. When your valve opens, you should be ready with a flash light inorder to watch for any drips underneith the unit.
Could be a simple fix of just tightening up a bolt, or could be a repairman issue.
Good luck.
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
SOURCE: GE tFX26KR side by side leaks water onto floor
I read this on-line and it worked for me - - pour HOT bleach water down the drain once you get the ice out. I had this problem for ages and would periodically clear the ice out of the bottom of the freezer but since the bleach water went down that hole it has been clear for months. Of course I discovered my s/s had been recalled for a water problem.
The GE recalls are a joke anyway - a credit toward buying another GE product. Nope, I am replacing my GE's one at a time with a different vendor.
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
