During laundry yesterday I noticed the dryer had stopped. When i opened it the clothes were still damp and the panel did not light. I did however notice that the interior light was working. The breaker and recept both proved to be fine. Any suggestions ?
Possible bad connection to the cord, inside the dryer.. unplug it, remove the rear panel, and do a continuity check with a meter.
Dead on accurate. Funny that when I had pulled the unit out a few weeks back to dismantle and clean the lint out of blower and what not i noticed a spark in the back where the cord housing is. I thought it was simply an igniter of sorts and dismissed it. After your advise I pulled the cover and checked the power supply to find out the connections have been corroding. Thanks for your help ! No $200 circuit board needed !!! Wohoo.
SOURCE: it will not turn on
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
SOURCE: Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
SOURCE: While I was out of town my wife was drying clothes
you must check if there is power to the element when you have it switch on , , if you have no power to the element , then trace the wiring from the element to a hi limit thermostat , it a small round disc shape item about the size of a 10 cent coin with two connections , remove the wires and check continity accross the two terminals, if it is ok , then check the on and off switch or timer dial , you might see burn marks around the connections , since it trip the circuit breaker
SOURCE: I have a Maytag MCE8000AYW. I went to use the
you may have a bad panel but there is on the exhaust ( blower housing a 1 time thermo that can shut the unit down . and this is caused by poor air flow . so ck the termo ( fuse and the air flow . . ) this should correct the problem and then the panel ...mm
SOURCE: Clothes dryer works fine but
HI CHECK ELENT AND STATS ...THERE ON REAR OF UNIT ,,,UNPLUG FROM MAINS FIRST AND TEST WITH MULTIMETER.
