SOURCE: 2004 suzuki volusia 800 speedometer stopped
I had this same problem its the teeth on the bottom of the speedo take your front tire off be careful with your brakes slide out the axle then just turn your front wheel to one side and the speedo wiil fall out I am willing to bet that the teeth are broken on the end they are made of plastic if you want something a little more detailed just drop me a line at [email protected]
SOURCE: Suzuki Boulevard Weird Noise
Its probably your fuel pump, but the noise should stop after a couple of seconds when its primed. Might want to have it checked.
I had this problem. there is a speed sensor in the front wheel hub. it is behind the brake and the axel goes through it. if you take the front wheel off you will notice it hanging down on a thick hose/cable. if it isnt aligned right when you put it back on, it will not read or will break off the little wings that seat in the wheel. the piece i am talking about normally falls out when you take the wheel off. the housing for it is what I described above. it is the flower looking piece in the pic in the link below.
http://www.oneidasuzuki.com/store/parts-accessories/speed-sensor-speedometer-vl800-2001-05-c50t.html
SOURCE: Troubleshooting 2005 Suzuki Boulevard C50 Motorcycle, Support & S
there is a set of fuses ....... when standing facing the side of the bike that has the clutch on it.... look down at the section of bodywork rearmost (closest to the rear wheel) this section can be unscrewed. in this you will find the relay for the starter motor and the indicators. as well as a small box type containing a number of fuses.
SOURCE: how many quarts of oil in suzuki C90
My 2007 C90t which is the same motor as yours requires 4 1/2 quarts of 10/40wt.
Stick with Suzuki brand oil btw. When I changed to Amsoil, I developed a problem.
