1999 Volkswagen Passat Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing 4 calipers and there is no oil com out when try to bleed
VW passat 99 the brack is stuck while driving then towe to grage they said 2 calipers ( 1 front & 1 rear) stuck.they change 4 calipers ,4 rotors
and two hoses after installing there was no oil come out when bleeding.Mechanic said something wrong with ABS pump it doesn't start with the car.Take it to dealer said Master need to be changed.after changing master the dealer said the lines was leaking and hoses were iinstalled wrong.We staill waiting .can some told me the reson is it master or ABS pump and if they install hose wrong can this cause no oil when bleed.
Thanks
  • mina_mesbah Jun 15, 2009
    Thanks.I forgot to say that the dealership mention that the master gone because the mechanic bleed it wrong he kept push the pedal all the way untill touch the floor and that made the seal in the piston to flip and that ruine the master .Can thios be the reason and can the master only send oil for rear only and doesn't send oil to front.I really appriciate if some body can advice
Bob Kovalak
Level 2:
  • Expert 181 Answers
  • Posted on Jun 13, 2009
Bob Kovalak
Expert
Level 2:
Answers
181
Questions
5
Helped
175064
Points
392
The master cylinder supplies the pressure to the brake fluid that travels between the maste brake cylinder resevoir and the brake caliper pistons (through the brake lines. If the master cylinder fails there will be insufficient compression of the brake fluid to make the calipers operate as designed. Leaks in the brake lines and/or cylinders is a possibility, and unrelated to functionality of the master cylinder. Also, pistons located in the brake calipers can form a corrosion ring on their inside walls if there is breakdown in the brake fluid or moisture that gets into the lines. Operating the vehicle when there is insufficient brake fluid in the master cylinder resevoir can also lead to air getting into the brake lines, causing bad working brakes. Air compresses more than brake fluid, and the master cylinder isn't designed to compress air in the brake lines. Sounds like a bad case of "lack of maintenance", as opposed to bad advice from the mechanics. That said, there's no excuse for bad installation. But, it's tough to improperly install a brake line since they are nothing more than hollow metal tubes. There should be no rubber connectors installed in the brake lines. When bleeding the brake lines one must remove all of the trapped air before you will see any fluid appear. If the valves in the master cylinder are not properly operating the master cylinder will not allow the brake fluid to get into the brake lines.
Hope this helps.
  • Bob Kovalak Jun 15, 2009
    The master cylinder should only have one (1) fluid reservoir. The same fluid reservoir sends fluid to both the front and the rear brakes. There is a small valve that feeds each individual brake line as it leaves the master cylinder. Master cylinders can fail for a variety of reasons, but I've not seen an instance when it failed because the brake pedal was depressed to the floor several times ????
I have a 99 vw passat with lifters issues...so here's how it went. I was passing a car when my check oil light came on...I stop check the oil, within a few minutes the lifters started clacking, I...
You should perform an oil pressure test and see if the engine is producing oil pressure within specification. If it is, the lifters may quiet down over time.
Replacing brakes on 99 VW Passat. Please advise how to push in the brake piston so it will fit back on the rotor & brakes
The fronts compress with a C clamp. The rears have to be turned in with a caliper retraction tool. In both cases, be sure to remove the brake reservoir cap before resetting the calipers, and put it back on before touching the brake pedal. Pump the brakes to get pressure before taking your first drive.
1helpful
2answers
Oil pressure low light, how do you change the oil pump or clean the pickup tube on a 2001 vw passat?
these cars suffer from oil pump problems and sludging of the oil. its probably going to be an engine out job as youll need the sump removed to get to the oil pump and pick up pipe. theres not a lot of room you might be lucky and just raise the engine enough but theres quite a lot to remove from the engine to do the job. hope this helps
How much do I expect to pay for new brakes
It will vary on the brakes, depending what needs to be replaced, rotors, calipers, pads. I would say around $200-$300 per axle. I've seen tranmission services going for $79-$99.
1helpful
2answers
Oil pressure light in 01 vw passat
CHECK ENGINE OIL LEVEL SOUND LIKE LOW OIL LEVEL.CHANGE OIL IF IT HAS BEEN OVER 3000 MILES OR OIL LOOKS DIRTY CHANGE IT.IF OIL CHANGE DONT HELP HAVE OIL PRESSURE CHECK TO SEE IF OIL PUMP GOING BAD OR YOU HAVE A FAULTY OIL PRESSURE GAUGE.
I bought used 2006 VW Passat with 52,000 miles. Oil level low and black color.. after changed oil find oil in coolant tank. engine runs ok... check engine on... any advice?
head gasket leaking. does the oil cap look like pudding stuck inside of it? if so that was caused by the tow fluids mixing together in the engine
Vw passat rear brake assembly leaking
It sounds like either You have a caliper that has malfuctioned or that you have a hole in your breakline skmewhere. Have you tried to bleed the brakes recently?
Handbrake in VW Passat 2007 got Stuck
a very common fault is the switch,the calipers are not much better,they will be able to sort it for you but they are bad news for a modern car !!
2answers
VW Passast low oil - light came on - ok to drive?
If you are not driving far no problem. If you are just put a quart of oil in it until you get to the station.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
