Kenmore elite heavy duty king size quiet pak 2
It will fill with water but will not spin when it's time to start the cycle it will drain but during the spin cycle and drain time it makes a clicking grinding noise.
  • 60 Answers
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Posted on Sep 14, 2007
  • 5911 Answers
SOURCE: water leak, back of washing machine during rinse or drain cycle.
The back panel does not come off. You need to remove the outer casing in order to access the internal components. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
With the case removed, you should now have full access to all the internal components and be able to complete a thorough inspection. If the leak is coming from the rear of the washer, check your water inlet valve and associated hoses. Inspect the tub ring where the water dispenses into the wash basket and make sure it is not cracked, or has any loose hoses. If you need assistance in determining where the leak may be coming from, please let me know.
To reassemble the washer, perform the following steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions along the way, please let me know. I hope you find this information helpful.
Posted on May 15, 2009
  • 3113 Answers
SOURCE: My kenmore elite heavy duty king size model #
That is what I suspected. Thanks for the reply.
Posted on Jun 16, 2009
  • 1026 Answers
SOURCE: Washer is a Kenmore Elite Heavy Duty
Hey Steve!
To answer your question, no. They usually don't have a Thermal fuse. They aren't that suseptable to overheating (most of the time). You most definately would want to have a technician service this unit. You REALLY have to be experienced to work on these front loaders. They are LOADED with electronics that monitor and control everything that happens with the unit.
Posted on Dec 14, 2009
  • 15935 Answers
SOURCE: What capacity is a Kenmore Elite, king size, heavy
3.8 cu ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
  • 4059 Answers
SOURCE: How many gallons of water
You can figure it out by catching the water for 10 seconds in a container and measure the amount and multiply that by 6 to see how much you get in a minute then see how many minutes it takes to fill it out and multiply that by the amount you get in 1 minute.
Posted on Nov 04, 2010
0 characters
1 Points
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
My Kenmore elite heavy duty king size quiet pak II Top Load washer stopped in the middle of the wash cycle and began to give off a burning rubber smell( I think it overheated). I turned it off and removed...
The pump is connected to the same drive that drives the tub, if the coupling is bad then the pump won't work. Does the motor start and try to run? Do you hear a grinding sound when you start the motor? If so then I would suspect the coupling is bad. this is not an expensive repair, should be right arond $100.00 to replace the coupling and you migt want to get the agitator tabs replaced as well since they wear out about the same time as the coupling. This will only add about $10.00 to the repair. The drum has to spin to pump the water out!
Nov 13, 2010 | Washing Machines
No locomotion or spinning of basket
i would check the coupler on this unit
it sits between the motor and transmission
this is a three peice part it is a rather easy repair
just goto appliancepartspro
type in your model number
look in the motor transmission block
motor coupler
Oct 13, 2009 | Washing Machines
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washing Machines Logo
644 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
