Question about Roxio Easy CD & DVD Creator Platinum Edition for PC
Drag to disc file
I copied a file to a disc using roxio 9 drag to disc with the setting to open only with drag to disc program.  Is there a way to open it without the program
    Novelist:
  • 233 Answers
Make another disk and do it, so it works the way you want it to work.
Posted on Oct 31, 2007
I copied filed to a cd through windows vista. i also have roxio installed on my computer. now the cd wont read files in windows. it will read them in roxio but says i cant copy them. they were...
From here.
Click START PROGRAMS Roxio EMC8 Tools and select Disc and Device Utility It should recognize your drive(s) Insert the disc If it says the session is still open, click on that line to highlight it and press the FINALIZE SESSION button.
Mar 09, 2011 | Roxio Computers & Internet
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
I installed roxio creator 2010 successfully but I can't open the desktop icon.
go to my computer/program files/roxio easy creator 9 suite and copy and paste the quick launch icon and place it on your desktop
Dec 30, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Dvd software won't install in vista computer
you could try dragging the files from the roxio installation disc onto the desktop. or if downloaded then just go to the setup file. when you find the setup file right click on it then go to properties - compatibility and then click on run this program in compatibility mode for: xp then further down click on the run this program as administrator.
Please let me know if this works and give me a fixya rating if it does.
Thanks
Apr 05, 2009 | Roxio Easy DVD Copy 2 Premier Full Version...
Password lock
The default password is 136900. This is the factory password. This information can be found at the following link. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 It is in the owners manual on page 47. I hope this information helps you with your problem.
Feb 21, 2009 | Philips DVP5990 DVD Player
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
To run the Program Compatibility Wizard
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Jun 25, 2008 | Roxio Easy Media Creator 7
Maxell cd-r 700mb- where have my pictures gone??!
use cdr's and allow multisession in your settings. Get rid of roxio and use nero 7.5 or above. Roxio tries to format cd-rws all the time if you have all features installed. bakup program keeps wanting to format cdrw. so use cdr's instead..Use the data disk option. That will copy your pics fine.
Craig
May 31, 2008 | Microsoft Windows Vista Ultimate Edition
Disc copy program not working
try uninstalling then reinstalling the roxio program
Apr 01, 2008 | Roxio Easy Media Creator 7
Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
Nov 07, 2007 | Roxio Easy CD & DVD Creator 6...
Roxio Easy CD & DVD Creator Platinum Edition for PC Logo
127 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
