Transcend USA 120GB Storejet 2.5" SATA - Titanium 120 GB USB 2.0 Hard Drive Logo
A
Anonymous Posted on Mar 10, 2014
How to fat32 to ntfs - Transcend USA 120GB Storejet 2.5" SATA - Titanium 120 GB USB 2.0 Hard Drive
2answers
How can I view content on my flash drive, on tv . I can't access the file when I plug in the usb stick
It is very likely that your TV doesn't support files what you have on the stick. Can you access files on computer? If answer is yes then your stick is working. If that is the case check your TV manual for file types supported by TV and also for file system format for memory stick (FAT 16, FAT32 NTFS....?). You may have to change format of your USB stick or recover your files to format recognized by tv. For example tv may read pictures in *.jpg format but not in *.png.
tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 • Computers & Internet
tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 • Computers & Internet
1helpful
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
My laptop cant find the harddisk
Explain your problem in swedish and i may help you.
you cant format both NTFS and Fat32..its either NTFS or Fat32.
But as i i told you above, explain the problem in swedish and i will try to help you.
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Win xp change d drive to ntfs, now it is fat32
Is the D: drive removable media? If so, the media you have inserted has to have been formatted with fat32 rather than ntfs. It shouldn't matter... either should be able to be read. Changing from ntfs to fat32 requires a formatting of the drive... so the OS can't simply change it.
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
