Question about NEC Electra Elite 32D-1 Corded Phone
Voice mail on/off
I have a button on my reception phone labeled "night" which turns on and off the voice mail.  Is there a way to turn it on/off from another phone in the office (I have the 32D and the others are 16D)?  Thanks
  • 43 Answers
  1. The Night mode of the phone system is merely a second ring pattern on the phone system.
  2. The phone turning Night mode on/off must have Attendant features set.
Posted on Feb 12, 2008
Try hitting feature 80 feature. It should work from any phone on your system.
Posted on Jan 09, 2008
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
Can i turn off voicemail
To turn off your voice mail automatically, turn off your phone and turn it back on after 5 minutes, then you enter ##002# and press the green/dial button, it will automatically deactivate the voice mail from the phone. Then test it by dialing the number of the phone from another phone to see if it will go to the voice mail or it will ring normally. I trust it will ring normally after doing the ##002# and dial voice mail reset.
Hope this helped you. Thanks for using fixya.
Jan 26, 2011 | Samsung SGH-G600 Cellular Phone
How do I change the message on my reception phone?
Hi,I am assuming that you mean the voice mail greeting. If this is the case at your reception phone press the Voice-mail key, enter your passcode, then enter 0, 5 , 7 the prompts will let you listen to the current greeting, then press 3 (to discard and re-record you greeting message) press the # key to save and NOT button 2. I have sent you a helpful video about how to use the DCS Voice Mail. More like this are available to view on Youtube search 'abbeytel' or go to
Nov 24, 2010 | Samsung DCS 12 Corded Phone
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Program a button for Direct Voice Mail
press speaker 00
press the button you want to program
press *56
Press the speaker button.
Label your button
Nov 14, 2008 | Avaya 4412D Corded Phone
Night button and voice mail
Sounds like the voicemail might be off?
Is the system time and date correct? It could be that you lost power, and all the programming that tells the phone system where the voicemail is.
Jun 18, 2008 | Lucent PARTNER18 Corded Phone
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
How to turn off voice mail on A V3 RZR phone
try dialing *780, you should hear beep beep beep confirming that it is turned off. press *78 to reactivate.
Dec 26, 2007 | Motorola Mobility RAZR V3
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
331 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
