Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2100 bag light stays on and power won't cut on
What could the problem be?
  • 8 more comments
  • Anonymous Mar 10, 2008
    Won't turn on and the question mark lights up.
  • bagged up Mar 30, 2008
    I have the same problem. The bag indicator light goes on after I just replaced the bagwitha new electrolux bag. I checked the hise for possible
    blockage but didn't find anything. Everything looks clear.
  • jullllllbs Jul 02, 2008
    I have the same problem, the bag light says full and the vacuum won't run. Everything looks clear, I've changed the bag, and checked out all the hoses. The only way the red bag light goes off is when I unattach the hose from the canister.
  • apex16 Jul 13, 2008
    put bag in light comes on hook hose up will not work
  • justcarol Aug 02, 2008
    Bag light stays on. Vacuum will not run. I have changed the bag, checked the hoses. Everything looks clear.
  • bkdomer92 Aug 30, 2008
    Power light comes on. Full bag lights comes on. No power. Replaced with brand new bag and checked to see if hose is cleared. All clear, new big but full bag light remains on and still no power.
  • cdaddy Sep 16, 2008
    bag light stays on, powers on then shuts off immediately.
  • luva2win Sep 30, 2008
    same thing here... the light doesnt shut off so the motor doesnt work. if i take off the hose it works fine, i checked the hose there is no obstruction. what do i do....
  • oalicia_ Oct 16, 2008
    The bag light is on- changed bag- light is still on and vacuum will not run
  • telizabeth Feb 15, 2009
Posted on Nov 12, 2007
2 Suggested Answers
  • 134 Answers
SOURCE: electrolux 2100
sounds like the hose is blocked. Drop a coin throgh it to check
Posted on Feb 20, 2009
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start"is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 | Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Why does my change bag light keeps coming on even after i change the bag, on my electrolux 2100?
The bag or main vacuum switch could be malfunctioning and in need of replacement. Hope that helps!
Jun 26, 2014 | Electrolux Vacuums
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux 2100 does not turn on. the light bag full comes on even with a new bag
The bag might not be seated properly or you are using the wrong type bag.Try reseating the bag.
Jan 20, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
833 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
