Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
32" Sony Trinitron made 10/1994
The color went out, now its just blk and white. Now the color for the menu options and for the channels is still there... If you leave it on for awhile sometimes you can see the color try to come in from bottom to top, but it never quite makes it, it tries for about 3 to 4 seconds... This tv is old but has very little hours on it maybe half the life, I bought it new.. thanks alot for your time!!!  32" Sony Trinitron made 10/1994
  • 116 Answers
Re: 32" Sony Trinitron made 10/1994
Probably bad solder connections in the video processor area.
Posted on Mar 01, 2008
0 characters
3 Points
I have sony wega trinitron and a day back purchased a new LG DVD player but the picture is black and white.I tried the Setup to change the color from auto to PAL but the option color change is permanantly...
Your TV model has only NTSC system with it. No PAL or SECAM. It is not a mutisystem compactable one. Check whether your DVD has NTSC playback option. If it has, you can see discs writed in NTSC system through your TV. If it has not equipped with that system, it is useless for your TV. Sony KV32FS120 and KV36FS120 models are only meant of US standard, and have only NTSC system with it. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony trinitron about 27 to 32 inches. it was left in the house when i moved in so there is no manual and no remote. I bought a universal remote that works but the tv is programed to certain...
Hi, if you have the remote control you go in the menu and you browse to set up and you choose air/ cable
and you set it to air or cable thene you press enter then you look for channel programing and press enter
and you will be don if dont have a remote you have a
menu button on the tv set push on and you browse
with channel up or down and select the option you want with volume + as i describe in the text.
hope that will help
have a nice day
Mar 28, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Video 4 channel to color from black and white?
There is no option for changing this, is video 4 a component input? maybe the format is wrong (yellow instead of green)?
Jul 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinatron has no menu control, can't auto add channels
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVD player only plays in black and white
there must be some options either in tv mod or in dvd, is not properly selected..
check both manual in details...
dont forget to rate
Aug 10, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Close caption
the Caption cannot read the signal using the video in connector,
you will have to use the channel 3/4 output from the converter.
the video signal won't be as good though.
your satellite box should have the CC option within it though.
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
193 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
