Question about LG DR197 DVD Player/HDD Recorder
LG rh7624w How do I reset the LG to the factory settings after I changed the normal / wide screen ratio, and can now not get any visuals on my TV screen ? Keep in mind I can not see any dialogue from the LG. Thanks
Re: LG rh7624w
Call their tech support. The # is on the DVD.
Posted on Jan 21, 2008
0 characters
3 Points
Reset dvd player
The player works off the source..the 16:9 is a function of source and your tv display (usually denoted as "wide" key on the remote)
Mar 18, 2014 | LG DVX583KH Player
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
For some reason my dvd player wont show my dvds in widecreen all of a sudden. It's set to HDMI, 16:9 ratio and auto fit
all units are different, check the menu on the dvd player, is it still on widescreen. Also, is the tv still on wide screen
Mar 06, 2011 | Toshiba XD-E500 DVD Player
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Mar 31, 2009 | DVD & Blu-Ray Players
How to change regional settings
Hi and welcome to FixYa,
Appreciate the direct "Ask Me:.
Initially, for the LG RC897T, pls try:
  • Click the HOME button on the remote with the unit in 480i resolution
  • Click the setup page
  • Click Start
  • Click TV Aspect
  • highlight the 16x9 wide aspect ratio
  • enter on remote control this coded sequence:
  • 1 3 9 7 1 3 9
Edit specific "Options"
  • Option 2: 35 (enables Divx/Xvid playback)
  • Option 4: ff (enables Vcd and SVCD playback)
  • Option 5: ff (enables region free playback (region 0) DVD playback)
  • Option 6: ce (enables Insignia brand startup logo on boot)
  • Option 6: c0 (enables LG brand startup logo on boot)
This has been posted on the Internet here and here for an LG RC797T and was discussed here.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate this at all. Cheers.
Dec 30, 2008 | LG RC897T DVD Recorder/VCR Combo
While having one too many beers my friend managed to use the remote to get to the 'secret' Service Technician Menu for my LG RC797T DVD recorder to make it Region free. This he did mange to do, however his...
In 480p resolution, you highlight the 16.9 aspect ratio from the TV Aspect menu option in Setup and then type 1397139 on the remote. This brings up the service screen with all options and machine information.
Optimal (best) settings are as follows.
1 : f 2 2 : 35 (this is DivX)
3 : 93 (macrovision?) 4 : f f (Vcd/Svcd)
5 : f f (region free) 6 : c0 (c0 = LG logo)(ce = Insignia)
7 : 04 8 : 15
All I can say is Keep these and and dont mess around or you can kill it....
Apr 17, 2008 | LG DVD & Blu-Ray Players
Ld dvd hdd player rh7624w recorder
Same as for the LG RC195. Turn on TV and player, press home key on player remote; in setup, scroll down to the padlock icon (when you get to the "padlock" option on your remote, leave it there, don't go to the menu to the right which has three options--rating, password, area code. Leave it on "lock", press 0000000 and you will be region free.
Feb 24, 2008 | DVD & Blu-Ray Players
To make the unit play all regions do the following: 1. Put in a DVD that will play (in our case region 2) 2. When it starts playing, press eject 3. While the drawer is open press "0" seven times 4. When you get the "Congrats" press Enter and done! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | LG DR197 DVD Player/HDD Recorder
LG DR197 DVD Player/HDD Recorder Logo
684 people viewed this question
Top LG DVD & Blu-Ray Players Experts
Electro Med Services...
Are you a LG DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
