The time on the clock was always accurate until it changed for daylight savings time. Now it's 12 minutes fast. How can I fix it?
SOURCE: Clock resetting problems
You might contact your cable provider and see if their system indeed is broadcasting this subcarrier information. If so, is their system on the correct time? You might be able to turn this feature off on your VCR. Another thing to try, is disconnect the VCR from the cable system, set the clock, and see if it stays on time. This may indicate whether it is indeed locking it's time to the cable provided time.
SOURCE: Sharp Carousel 2 Convection Microwave R-1810 (Feb
Simple fix.
This
is a problem in one of the damper-related components, either the switch
or motor or the damper door may be binding.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after
59 seconds.
See the attached sample
drawing for a typical damper assembly.
We have the service manuals for similar models and have uploaded them to our site here and here to help you.
Note that the part numbers will likely differ.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
If you need a damper motor, contact Encompass here
or call them toll-free at
866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My sharpe aqous runs for
Tries unplug,replug tv an hour later.Let the tv reset itself.Than goto tv Menu go to PICTURE,go down to reset.This will reset everything on the tv Tuner board back to factory setting.This should solved ur problems.Not,than the tv Tuner board have intermitten isuse problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
SOURCE: how to I change time, tv did not update auto to daylight savings time, sharp aquos lcd tv
With the remote look carefully in the set's menu and adjust it (look in setup first).
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
