Question about Texas Instruments TI-30XA Calculator
Calculate future population
How do you use this calculator to calculate future population?
6000000000 at a growth of 1.01 over the next 24 years
  • 63 Answers
Re: calculate future population
The formula for population growth is:
population * (annual growth rate ^ number of years)
In your example,
6000000000 * (1.01^24) = 7618407891
To get your calculator to perfom the calculation, enter it in the following steps:
Type 6000000000
Press the multiply key
Press the ( key
Type 1.01
Press the yx key (located right above the divide key)
Type 24
Press the ) key
Press the = key
You can reuse this formula, substituting any values you wish for the current population, growth rate, and number of years.
Posted on Nov 12, 2007
Solve the equation of regression line for two varaible and three varialbles
Posted on Apr 19, 2011
To calculate the future population the correct formula is Current Population x Total Fertility Rate / 2 x Future Life Expectancy / Current Life Expectancy or CP*TFR/2*FLE/CLE
Look up The World Bank and CIA Factbook for further info.
Posted on Jul 29, 2009
I don't think this is either A) the correcto formula or B) the correct way to solve it. So i really think this should be in the unsolved problem catergory. in 24 years the earth's population on its current trend of 1.01 would have it way higher than 7.6 billion.
Posted on Jan 23, 2008
0 characters
3 Points
How to calculate effective annual rate
Hi there, if you are following the example from page 24 of the manual - The steps are as follows - reset or clear the previous values by pressing the orange key (2nd F) and MODE.
Then make sure that BGN is not displayed (To do this press 2nd F and FV (above it you will see BGN/END)). To set the number of payments per year press 2nd F I/Y (above it is P/Y). Type in 12 and press ENT. Press the down arrow key and to make sure C/Y also says 12 (12 compounding periods per year). Then press on. Calculate the total number of payments - to do this type in 20 2nd F N (to get xP/Y) and then store the answer in N by pressing N again. (Your screen should say ANS -> 240.00)Type in your present value 56000 and press PV to store it. Enter the monthly payment press +/- 440 PMT. Enter your future value (press 0 then FV). Now to calculate the interest rate press COMP I/Y. It should give you 7.17 %
A very common error is not pressing N to store the number of total payments into the calculator.
If this is not the example you meant, please let me know - and I will explain the other example.
good luck
Jun 23, 2014 | Sharp EL-738 Scientific Calculator
How do I use log
to explain what a logarithm is, it's to involved to explain here but check for a detailed explaination of it
i use it to find root and powers of numbers. it turn up in certain natural process like radioactive decay, population growth, interest calculations..etc
for square rooting a number
square root of 16
type 16 press the log ( I'm using a scientific calculator a TI 30s to be exact) key to get 1.204119983 for a result divide by 2 to get .602059991 press shift or 2nd log key ( to get the 10^ key - this the anti- log key) to get 4 as a result
I hope this helps
May 25, 2014 | Texas Instruments TI 30XIIS Scientific...
The formula a= 22.9e 0.0183t models the population of texas,a, in millions. t years after 2005
And the question is?
To calculate the population at a future date , calculate the number t=future year -2005 and substitute this value for t in your expression
a (future year)=22.9*e^(0.0183*t)
Oct 23, 2013 | Calculators
Growth rate between two periods population in 2000 is 206,000 and population in 2010 is 240,000. how to use calulator to get the growth rate used
You must first understand the problem on your own before you can do it on the calculator.
Calculate the difference in populations 240 000 -206 000
Calculate the time difference 2010-2000.
Divide the difference between populations by the difference in years.
Multiply the result by 100 % if you want a percentage value.
Feb 07, 2013 | HP 10bII Calculator
The initial population of a town is 2800, and it grows with a doubling time of 10 years. Whay wi the population be in 12 years
The population doubles in ten years so the annual growth is the tenth root of two. The growth in twelve years is the annual growth rate raised to the twelfth power.
The tenth root of two is about 1.0718 . That value raised to the twelfth power is about 2.2974 . Multiplied by the initial population of 2800 gives 6433.
On the TI-30XA press 2 2nd [xth-root] 1 0 = y^x 1 2 * 2 8 0 0 =
Nov 05, 2012 | Texas Instruments TI-30XA Calculator
Use Casio fx570ms to calculate growth rate between two periods
Usually, population changes are not linear, but since you give only two points (2000, 206 000) and (2010, 240 000) that is all you can calculate. The average growth rate is given by the rise over run.
Growth Rate=(240 000-206 000)/(2010-2000)=34 000/10
Jun 25, 2012 | Casio FX570MS Scientific Calculator
Hi: I bought a HP 10bii Financial Calculator. I find it difficult to get a correct answer... For an easy example, I try to find the future value of $100 today after 3 years with an annual interest rate...
What you've done is calculate the future value after 3 months, not 3 years.
Press 1 SHIFT [P/YR] to set the payments per year to one. Now the FV key should give you 115.76
Feb 15, 2011 | HP 10bII Calculator
Future &present value
That depends on the interest rate.
2nd [CLR TVM] (clear previous data)
5 0 0 0 PMT (monthly payment)
2 0 2nd [*P/Y] N (20 years of monthly payments)
annual interest rate I/Y (annual interest rate)
CPT PV (compute present value)
At 10% it's about $518,000
May 26, 2010 | Texas Instruments BA-II Plus Calculator
your best bet in any kind of exponential equation is to set up the general form of the equation and then solve for the constants with the numbers they gave you. With P being population, t being time, you know it is going to look like P=Ae^(b*t) and you are given 2 P's for 2 t's.
So for the first set :
Eq 1 P(26)=40,000=Ae^(b*26)
and the second being a time t=0 P was half the current value:
Eq 2 P(0)=20,000=Ae^(b*0)
20,000=A*1 so A=20,000
now b from Eq 1
Aug 04, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
5,105 people viewed this question
Top Texas Instruments Calculators Experts
Stevan Milanovic
Are you a Texas Instruments Calculator Expert? Answer questions, earn points and help others
