Question about Toshiba Satellite 5005-S504 Notebook
New screen not as light as it should be
I'm helping a friend with the smashed screen on his Toshiba Satellite M70-340. The original screen is a glossy screen with the following reference: NTL154X3.
I got him a matte working screen with the following reference: PL154W01. When I replaced his screen with the new one, the light on the new one is a bit dim.
When I change the brithness setting I notice a change on the brithness of the new screen but is still about half what it should be (it is as bright as when the computer is running on the battery).
Is the problem comming from the original inverter not providing enough power?
Please help me to figure out the problem.
I'm connected to skype at the moment under the name 'cat_mine'. please get in touch if you have any idea on how to sort this problem
thanks
N.B. With the new screen in the keys that adjust the brightness work in revers order; the one suppose to increase the brightness decreases it, and the one suppose to decrese the brightness increases it.
  • 83 Answers
You didnt get the right replacement for his model thats why brightness is low and also why the display buttons are in reverse if he continues to use it it may cause long term damage and may affect the correct screen if and when he gets it
Posted on Oct 29, 2007
SOURCE:
Toshiba regza replacement screen
Screen replacements are usually as much as a new TV. Since it's Black Friday, you might be better off shopping for a new TV.
Nov 28, 2013 | Televison & Video
Toshiba Windows 7 satellite pro. screen goes
DO NOT OPEN/CLOSE THE SCREEN ANYMORE(or move it at all)
Your laptop is damaged from the hinges which is a pretty common issue
The only solutions would be to:
1) plug in a monitor
2) buy a new laptop
Sep 08, 2013 | Toshiba Computers & Internet
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
Hi i have a toshiba satellite l300 and ive tried alt f10, f8, f5 and tapping the 0 key but nothing happens can someone help me with this!
tapping the f8 key is done when the toshiba screen first lights up on the screen when you turn on this computer
Sep 19, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba REGZA 37AV555D smashed screen
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
Dec 15, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Found a Toshiba laptop, about 2 years old. Screen
at two years old it is basically exctinct already and the costs of laptops coming down so rapidly you can probably go on craigslist or ebay and find a cheap laptop that is working and ready to be portable. you can also try and sell the toshiba online for parts
Sep 02, 2009 | Toshiba Satellite A135-S4427...
REFORMAT TOSHIBA SATELLITE L25 S1193
It is not clear what you mean by restore here... do you want to salvage you r personal data on laptop or just want to restore the OS... which you said you have installed XP.
the copied recovery disc may not be booting for various reasons...
1.not set to boot fromcd drive in bios settings.
2. cd copy was not cd to cd copy or it was not made bootable. maybe you just copied the data of the friends recovery disc.
Aug 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite 3000 hard drive
If you saved the old bios info on a floppy before you flashed your bios with the new bios info, you can reflash and restore your bios back to the original. However if you didn't save the info which is usually saved as a .bin file you still have a chance to re flash back to original settings. Use a friends computer with a floppy drive and download your original bios program from the toshiba web site or any other site which has bios flash programs/utility file to the floppy and reflash. If you laptop doesn't have a built in floppy you can use aexternal one that connects to the rs232 parallel printer connector. Thats if your laptop has one of these now becoming an obsolete port on most if not all laptops. As this port is being replaced by the USB port.
Jun 10, 2008 | Toshiba Satellite 3000-S353 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
