I was messing with the starting button and somehow i erased the gr, kg, and oz. Need them back.
Get back to the menu by holding 'unit' when powering up.
Set default values to below by hitting unit to increase digits, and z/t to save.
1 - 00 (press 'unit' until 00 is displayed, then press z/t)
2 - 15 (press 'unit' until 15 is displayed, then press z/t)
3 - 00 (press 'unit' until 00 is displayed, then press z/t)
4 - 05 (press 'unit' until 05 is displayed, then press z/t)
It will only save if you see an 'f' display before turning off.
There is a limit to the amount of times the unit can 'flash' to the memory. If you cannot see the 'f' display, the memory is full and you cannot change.
Hope this helps!
Mainstays EK5055 Digital Kitchen Scale 5kg/11lb
