Neovo S 19 19 in. Flat Panel LCD Monitor Logo
A
Anonymous Posted on Mar 09, 2014
Neovo s-19 reset it looks pink
I have a neovo f-419 and the monitor settings or options will not go away and keeps cycling through the options by its self can not get it to go away tryed unplugging and messing with all the buttons but...
Unfortunately theres not much else you can do, unless one of the buttons is stuck and visibly pushed in further than the others, it looks as though the control chip for your monitor is malfunctioning.
I have a Neovo !( inch monitor used as a security
First place to look will be for bad caps in the power supply/inverter section, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as [email protected] to have a RMA number and they will estimate you the repair fee if it is out of warranty.
I NEED THE SERVICE MANUAL FOR AN AG NEOVO E-19A MONITOR.
Good luck on that one...you can only get that if your a service center.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Power problem?
Try ordering a new power adapter from Neovo. Call them up. It could't hurt. Apparently adapters are tricky items. I have no idea how much they cost, but if its reasonable it would be a fair tade for the nuisance you are dealing with now.
http://www.neovo-usa.com/
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Email: [email protected]
Tel: 408-321-8210
Fax: 408-321-8211
Top Neovo Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
