Question about Hotpoint Aquarius WMA56 Front Load Washer
Washing machine my drum makes a banging noise even more so when on final spin
    Problem Solver:
  • 5 Answers
Probably a balancing spring broken it'll need attention very soon... it's not a big job but needs to be taken care of without delay
Posted on Oct 30, 2007
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
My washing machine makes a very loud banging noise at the start and end of the spin cycle and there is a scraping sound throughout the cycle as though there is metal in the drum. What could be causing...
If you have an older machine it is the un-even load distribution in the wash tub. The wash is not evenly distributed in the wash tub. The wash tub don't spin evenly and wobble instead.
Mar 30, 2012 | Washing Machines
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
MY WASHER IN FINAL SPIN STARTS BANGING OR SLAPINING LIKE A BAD BELT OR SHOCK, BUT THEY LOOK OK [ NO DAMAGE TO BELT / ADD, PREASURE ON TUB DOES NOT HELP ] NOISE IS ONLY ON HIGH SPEED OF FINAL SPIN FRIDG. #...
it could be 2 or 3 things wrong here 1 could be something as simple as an uneven load that would make the machine jump about and bang,it could also be the drum spider this is internal to the tub it holds the drum onto the drum shaft this could be broken or it could be one of the counter balance blocks as become lose all three would only really show when in high spin gd luck
Oct 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer frigidaire GLTF1670A
you need a new drum, wich is pretty much like buying a new machine
Jun 18, 2009 | Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
