Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Color on tv not maching
I have a sony tv mdl. KP51WS510 and its sopose to be hd ready but after i hoock my ps3 to it with a hd cable now the colors on my tv go nuts.
and it takes a wile before it gos back to normal i have remove the ps3 hd cables but it still does it would like to know how to fix the problem or is that it for my tv
                                          thanks
  • geras Nov 07, 2007
    when i say that the colord go nuts i mean thers likr 3 difrent colors and some times 3 difrent color lines going across.
    and to replace this thats the part # STK392 IC's?
    Genius:
  • 1,694 Answers
Sounds like convergence issue....Can you describe " colors
go nuts"..........If red green or blue separate, replace STK392 IC's
located on large heat sinks.........T.
Posted on Nov 07, 2007
  • Vista Electronics Nov 07, 2007
    STK392-560 to be exact and replace both for reliability...T.
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Jan 23, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Hd tv as no hdmi plug
There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
Cheers
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
No color
Sounds like you are having a issue with color format or a bad connection cable... In the US we use the NTSC color format, Japan uses NTSC-J, and Europe uses PAL. This matters quite a bit; if you have some Special Edition PS3 that they only sell in Japan and have it plugged into your Flatscreen TV in the UK no dice. Make sure you do not have conflicting regions for your hardware. Moreover, make sure the pixel resolution is not out of bounds for your TV's range. The PS3 has different connection cables for every kind of connection; RCA, HD, HDMI. I recommend using HDMI if your TV supports it.
Nov 28, 2008 | Sony Playstation 3 (PS3) Console
Color on the Sony Bravia
Check the cables. It sounds like the cable for blue is loose.
Sep 08, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Instuctions connecting ps3 to hd ready tv
The answer is simple really. You can't connect your PS3 to your TV with a USB cable. You need an HDMI cable.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
What tv do you have:
lcd full hd or hd ready
plasma full hd or hd ready
normal tv pal analog 60 hz
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
