Konica Minolta bizhub 250 All-In-One Laser Printer Logo
A
Anonymous Posted on Mar 09, 2014
Reset network configuration
My network configuration is deseable
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 15, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911694
Points
11959
Good day. Hoping to get some startup advice. I need to access a new newly reset Nortel 470 switch to configure
you need to reset the setting before you can get the access to the device. Hard reset should be good. once done, plugin to your existing LAN, discover the IP taken via DHCP. configure the device.
Web interface should help you to do quick configuration.
Default network security key for apple airport
The Network Security Key is possibly the same pw as the network you are attaching to. This device can be configured in so many different ways.
If you can't figure it out then use the reset button on the back or use paper clip in reset hole.
To set up and configure your AirPort Extreme to use AirPort for wireless networking and Internet access, use the setup assistant in AirPort Utility.
The manual may be of some help... Available here
http://support.apple.com/manuals/#airport
Good Luck
Trevor
Have the key but still can't connect to network
The encryption key maybe incorrect. I suggest you RESET the Linksys wireless router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
http://192.168.1.1
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
How to re configure ip adress
Go to the "Resets" menu and select the "RESTORE FACTORY SETTINGS" selection. This will revert your machine to the condition that it was in when it came from the factory. Remember, the default for networking is DHCP, so once reset and online, you could use the web interface to configure it further.
Reset password
When you clickRefresh network list, then Choose your wirelessnetwork and then click Connect to your secured Wireless Network, itwill asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Need network security key
It depends. Not kidding!
Depending upon the available hardware and access to the wireless router, it could be as simple as examining the outside of the router and reading the network key off of a label on the router. failing that, you would likely need to have an ethernet cable that you can use to connect directly to a port on the router. Note that not many routers will allow access to the configuration through the wireless connection. You might be able to get to the smart part of the router by then using your browser. You can usually find the router manual on the internet to get the default IP and admin password to access the configuration. If nobody changed the configuration, then just getting access to the configuration should display the wireless key.
If this router is on your own network and you've forgotten the password, and you want to add some equipment, then consider resetting the router to factory settings, and default SSID and key. Check your manual, but usually putting a toothpick into the tiny hole and holding it for a number of seconds will cause the router to reset.
Once the router resets, you can access the configuration and set your password and SSID to what you want. You'll then need to configure all your other equipment with the network name and key.
Even if you have a PC that does talk on the network with the router now, you probably won't get the PC to show you the key for the network in the clear.
Modem automatically not configured ( Network Adapter)
This happens with almost all the modems and routers. You can try resetting the modem ( you can find the reset button at the back side or underneath the modem ). After the reset, the modem should get auto configured.
Thank you
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
