After pressing the power button, the green light flashes. Colorful vertical lines appear and then the tv shuts off. What is the source of this problem? Is there a part I can replace?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
SOURCE: TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
SOURCE: Sylvania LC320SS8 32 in. LCD Television Hi my
The light staying on is afterburn or power stored in a capacitor to start up the solenoid.
The protection circuit has been invoked to protect other components from being burned out. This unit needs professional intervention.
Unplugging and leaving for a few hours will not fix it it will merely delay the inevitable.I suggest it is taken for repair ASAP and refrain from trying to run it to prevent major damage or even fire.
Please remember to rate our help++++Thanks for using FIXYA
Testimonial: "thank you for the advise keep up the good work"
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
SOURCE: I have a lc320slx sylvania tv and I pushed some
This problems will not be solved by a remote control.Ur tv Tuner board is dead.Take it to the shop they will order a refurbish the Main Tuner signal board for u and replaced it.It will cost about half the price of the new tv.
