Question about HP LaserJet 4250n Printer
Printer is printing gibberish
My printer is printing mutliple (over 20 pages) of gibberish I have to trun off printer if i did not it would have finish the stack of paper within it
what seems to be the proble,
  • kizzi Oct 29, 2007
    please give me a better answer just awhile ago i send a print and left and forgot and it printed oover 50pages ! thats alot of parer wasting with gibberish
    I installed it on another computer it is the same the thing and this computer is very new
    please it is frustrating now cant my work done
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
HP  for some reason has been having this problem for a long time. keep deleting the jobs, it may take awhile ( up to 5 min)
but it will go away.
I work a lot with HP's, so I've seen it a few times.
Posted on Oct 29, 2007
  • CheckitRight
    CheckitRight Oct 30, 2007
  • CheckitRight
    CheckitRight Oct 31, 2007
    Is this on a network? most of the times when this happens to me it was connected to a network. delete all jobs re-install driver.
    ( I've never had to take it that far, usually I just delete all   the jobs or I have the IT dept . take a look at the programm that's running.
    Last resort is to reset the printer to factory settings, but before you do that print out a menu and configuration page to see what everything is set to.
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
Prints blank pages and gibberish
You may have to shut down the printer completely, including disconnection of power. When you reapply power, the printer should be indicating it is offline so you will have to put it online again.
Dec 04, 2013 | HP Laserjet Pro Cp1525n Color Printer...
Kyocera prints garbage
driver issue. download latest driver and update printer firmware
Feb 09, 2013 | Kyocera FS-920 Laser Printer
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
Printer keeps printing one line gibberish and then scrolls on
1) click the printer icon in the tasktray to open the printer tasks and delete any active print jobs, and wait for the task to be deleted.
2) power off the printer and power it back on that should clear it.
3) you may need to power it on and off more than once.
Apr 13, 2009 | HP DeskJet 920c InkJet Printer
Prints pages with no words but symbols
Print test page from the printer. This prints fine? Then anytime a printer prints gibberish versus what you were trying to print from the computer means you should try one of two things. Download the most recent drivers from the products support site, install these. Be sure to uninstall the old drivers first. Another item that can cause gibberish print is a bad cable. Swapping out with a known good could solve the whole problem.
Print test page from the printer. This does not print fine? Then you are looking at something wrong with the printer. The cable and drivers would not be the cause because the only piece of equipment involved at this point is the printer. First step I would try in solving this. Download and update the firmware from the support site. If this does not work, then you may have a defunct printer. If you are under warranty, contact Dell tech support.
Mar 12, 2009 | Dell 1600n All-In-One Laser Printer
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Epsonstylus C62 prints gibberish when turned on.
How can I fix my HP J5750 printer that prints gibberish with a compatable HP PC.
Dec 25, 2008 | Office Equipment & Supplies
Printer printing gibberish
Are you sure it's not the drivers (or the program using the drivers)?  Try installing a ps driver and see if printing to it will solve your problem.  If so, just uninstall and reinstall.
If that doesn't work for you, try a new cable.
If that doesn't work, you're probably looking at a new formatter board (expensive).
You can test some things by pressing menu buttons, then item buttons till you get to :
  1. Information
  2. Configuration Page
If that prints fine, go to:
  1. Diagnostics
  2. Print Test Page
I think that's the name of the test pages, I can't remember now, I'll have to check at work tomorrow morning.  Let me know if I got it wrong.
Oct 29, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
426 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
