Question about Fuji FinePix E550 Digital Camera
HP Photosmart M425
Help!  I can't turn on the camera at all.  Tried changing batteries.  I get nothing.  Not even a light.  Worked fine 2 days ago.
  • GUITARNUT Nov 27, 2007
    CAMERA IS 2 YEARS OLD. NEVER HAD ANY PROBLEMS.WENT TO USE THE CAMERA THE OTHER DAY.PUSHED THE ON BUTTON......NOTHING.REPLACED THE BATTERIES,STILL NOTHING.HELP.
Camara has been working fine till yesterday, poewer won't turn on, to take pictures, but it turns on when i moved the tab to brouse pictures, bur when I switched it back power won't work
Posted on Dec 16, 2007
SOURCE:
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Lans error.m425-11 ..............m425-21
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | HP Photosmart M425 Digital Camera
Pictures are almost black even with flash
I'm sure the problem is NOT the battery, try to put the camera in automatic mode or in easy mode. If that doesn't help look if the lens are clean and spotless.
I hope it helps.
Jul 27, 2010 | HP Photosmart R707 Digital Camera
The camera does not respond.
You need to return the camera...it is defective and will never make you happy.
Mar 27, 2010 | HP Photosmart M425 Digital Camera (5MP,...
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have an HP 735 photosmart digital camera and it wont turn on The window lights up and it makes a noise as if it will send the lens out but nothing happens then the window light goes out.A few days ago I...
even tho my batteries were fully charged they wouldnt work in the camera till I got new ones and charged them When I put them in the camera worked!
Jun 24, 2008 | HP Cameras
Lens Error M425-12 (7F80) on HP M425
Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
May 13, 2008 | HP Photosmart M425 Digital Camera (5MP,...
HP photosmart m425
can you help em upload videos?
Dec 08, 2007 | HP Photosmart M425 Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Fuji FinePix E550 Digital Camera Logo
77 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
