Black & Decker CTO649 Toaster Oven with Convection Cooking
Problem for Black & Decker CTO649 Toaster Oven with Convection Cooking
Black & decker toster oven
By G Bob Willy on Oct 29, 2007
toater works but oven does not work
Same Problem
May 24, 2009
-   On the toast setting it works fine-all elements work, but when you switch to the oven or broil settings nothing works. I think it's the top switch / potentiometer has gone bad....... darn thing isn't very old!!-   Guest
May 27, 2008
-   I have a similar problem with the same &D toaster oven. I love this toaster oven, and have had it about 10 months. For the past month or so the toaster works just fine, but the oven has stopped working. When I turn the switch in the oven position the light does not come on, nothing happens. However, one time last week when I tried to use the oven it worked perfectly fine -- but has not worked again since then. It obviously has to be either a bad switch or something loose. -   ZobVa
Nov 26, 2007
-   Same Model Black & Decker CT0649.
Oven Top Heating Elements Work OK
Bottom Heating Elements Don't Work
Found one of the heating elements spring heating wire broken off it's end mounting connection.
This bottom heater is tied in series with the other heating element on the bottom
If one heater opens in the quartz tube, neither will heat.
TcJ
t42and@aol.com-   knightnu
Best Solution
posted on Jul 25, 2008
Very Helpful)
klezwoolfe
Rank: Apprentice
Rating: 95%, 7 votes
I don't know if this applies to your model, but inside the right side are all contacts. At the top is the oven switch. Sometimes the contacts build up corrosion/resistance. Burnish/file contacts and it may work. My toaster was hard to get apart and put back together.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 30, 2007
Helpful)
edphallion
Rank: Apprentice
Rating: 95%, 5 votes
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Was this helpful?
Yes
No
Solution #3
posted on Dec 13, 2009
Not Rated)
dtheo
Rank: Apprentice
Rating: 0%, 0 votes
I have a B&D Perfect Broil - CT04300W that the top heating element will not work on any setting. Any ideas?
Was this helpful?
Yes
No
Solution #4
posted on Dec 02, 2009
Not Rated)
noon2005
Rank: Apprentice
Rating: 0%, 0 votes
The top heating element of countertop oven is not heating what can I do
Was this helpful?
Yes
No
Popular Solutions for Black & Decker CTO649 Toaster
Questions and Unsolved Problems for Black & Decker CTO649 Toaster
Do you recommend Black & Decker CTO649 Toaster Oven with Convection Cooking?
Answer
Answer
Needs Bake/broil & tast control I need to purchase a control
Answer
Where can I buy the switch indicated in the request by "htphtp"--the Black and Decker... (More)
Answer
At first the toasting function worked, but the oven temperature dial would only work on a few... (More)
Answer
Black and decker countertop oven CT0649; where can you find the potentiometer part?
Answer
cooked a roast in it for 2 hours at 350, by the time it was done cooking my counter top underneath... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Toaster Oven Experts
Top Small Appliance Repairmen
in , HI
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
