Question about Lands Phones
Radio Shack 43-3880 5.8GHz digital answering system - error codes
Base unit display flashing "8" and "88" repeatedly and then after several minuteseventually displays "E4" steadily. none of the keypad inputs register - unit is basically non funtioning with the exception of the display. no dial tone on base unit or on any of the handhelds. Manuall trouble shooting guide has no suggestions for this conditions nor does it contain any error code definitions. Have unplugger and replugged unit power source (to see if it would possibly reset) with same results. Would appreciate any assistance or suggestions you could offer.
Thank you.
  • 7 more comments
  • Anonymous Jan 31, 2008
    I have the excact same problem.
    Mark
  • MikeL68 Mar 27, 2008
    I also ran into this problem today.
  • Anonymous Apr 14, 2008
    THERE IS NO DIAL TONE ON EITHER PHONE ,HOW DO I SET IT?
  • Scott40 May 06, 2008
    have the same problem answering mach displays E0
  • Anonymous Aug 13, 2008
    I have the same problem. I've tried unplugging and it's not working.
    I have the same problem and unplugging it doesn't do anything
  • howardstalve Jan 05, 2009
    base reads e4
    base reads e4
  • Anonymous Apr 27, 2009
    The owners manual has nothing about this in it.
Well, bad news! After taking my phone to Radio Shack and allowing them about 30 min. to identify the issue, the result was that an E4 error means a non-repairable internal problem. If the phone is less than a year old, and you have a receipt, it is covered by warranty.
Posted on Jul 20, 2010
Http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303880_PM_EN.pdf
Owner's Manual Link
Posted on Jul 09, 2008
Need radio code for 2006 suzuki FORENZA
A local dealer can help. They will have a code based on your VIN. Also, you can try this: The audio security system is activated whenever the audio system circuit is disconnected from the battery. A four-digit security code must be entered in order for the audio system to resume functioning. The security code is stamped on a card located in the vehicle (usually in the glove box). The following security code entering procedure must be used to deactivate the audio security system:
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
If, after repeated entry of the wrong code, unit will enter "lockup" & will need to be repaired
Oct 07, 2015 | Suzuki Cars & Trucks
A radio code for a ford audio system please
your code is 4552
Once the unit has been turned on the display will show ' CODE - - -
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
May 20, 2015 | Ford Car Audio & Video
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
Hw do i enter the radio code for a ford transit 3000 traffic tape player. i disconected the battry and lost radio i got the code but dont no how to enter it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
May 26, 2010 | Radio Shack Cinego D-1000 Multimedia...
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
I have a ford radio thats been disconnected ive reconnected but can,t enter the code which the ford dealer gave me it just keeps flashing err
You will have to take the radio to a repair agent to fix this error either thecode provided was wrong or somebody has tried to enter the code wrong to many times, i use http://www.radio-code.co.uk/ford-radio-codes.html?gclid=CJiOvYas950CFeZr4wodQRNAqw you can send it in and they will fix it for a charge.
Nov 11, 2009 | Car Audio & Video
Base reads e4
Thank you.
Jan 05, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
PRO2096 Blank again 3mos after "repair" seemed to work
Since the repair fixed it for 3 months and it appears to be doing the same thing, repeat the process but be sure to put anti-oxident solution (if Radio Shack does not have, try a real radio parts store in person or online) on the ends of the cable so the metal will not "rust" so soon.
Aug 04, 2008 | Radio Shack Pro-2096 Base Scanner
Lands Phones Logo
1,141 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
