Apple MacBook Mac Notebook Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new 13 macbook fans are working properly.is it norm
I compare with the same version and it did nt work properly like mine.what should i do .please it really boder me.i bought it early 2009
Tim Digibrain
Level 3:
  • Master 846 Answers
  • Posted on Jun 06, 2010
Tim Digibrain
Master
Level 3:
Answers
846
Questions
0
Helped
1310084
Points
1356
There's a program called fan control. It will allow you to reset fan speeds. If fans are dead, they need replacement. If you want to do it yourself, the good news is, it'snot too hard to open a Macbook. Here is an Macbook Repair Guide that shows how to open an iPod. Just open it and let it try, clean off any corrosion you can find. If you want somebody else to do it for you go to iPad Repair NYC.
How to update minecraft
With the 1.6 update, Minecraft developers decided to require a new client download in order to fight piracy. If you have paid for the game, then just go to minecraft.net, download the client and sign in with the account you used to buy the game. If you are using a pirated version then you have to download a copy of the new version from your favorite torrent site. ;)
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Fan won't stop
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
I can't load facebook apps on my new macbook. This is a recent problem. What could be causing this?
remoce the existing facebook related files from USR/LIB and app folder.restart the system and reset PRAm followed by Apple.then reinstall th currect version of Face Book.It will work ok
Black macbook 13 will not boot.
you have logic board problem, check out if the fan, processor , harddisk working if not then it is logic board.
go to apple care and get the assistent.
plz rate this article. if you satisfy..
Ntl uk codes
nt hell 01 97 9B 22 E0 5B 13 B1 C7 JUST MINE IN THEY WORK LET ME KNOW IF THEY WORK FOR YOU PLEASE
2answers
Keybord fail
Your PC might infected by root virus/trojan, If you have 2 harddisk or might 1 HD with 2 partitions.. you need to reformat all drive... or try to install virus protection.. recommendation: http://www.threatfire.com/ (Free - Not trial version)
ThreatFireThen run it and try again..
Hopefully this be of some help/idea. Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
2answers
Need new screen
you would have to order it online or go to the nearest apple store
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
