Question about Frigidaire FEF366 Electric Kitchen Range
Oven not working
Range top still working, oven does not.  Display shows only "h.".  That's it, an "h" and a dot ".".  Have unplugged, reset the breaker, no change.  Any suggestions?
  • kimie01 Nov 09, 2007
    heard a popping sound and oven totally went out, will display temperature setting but will not heat up.
  • Cherish33 Feb 02, 2009
    We are having the same issue. LCD shows only a lower case h and a dot. Called Frigidaire and they said it is not a valid fault code. Suggested calling for repair.
Does it make a difference as to what type of cord?
Posted on Apr 17, 2009
    Problem Solver:
  • 5 Answers
What type of appliance cord goes with your model? Amp, voltage, prong number, etc?
Posted on Oct 30, 2007
Oven not working Follow the driections here to see if they work I had the same problem and this fixed mine.
Jul 30, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Stove oven dont work light clock work
Hello cdshowtel - If both the range part and oven is not working but it shows a display, I would suggest resetting the range. That can be done by either unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately because the unit could be experiencing an issue with a wiring failure or communication error with the EOC.
Nov 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
We had lighting come in and now our GE electric oven doesn't work. The range top still works but the oven display does not. Any idea's?
Look for a reset or fuse on the unit. If lightening hit, the surge could have wiped it out, as you already know. But hopefully GE put a fuse or breaker in the unit. You just have to find it, if it exists.
According to GE, a diagram is located in behind the control panel. If you can safely remove it (CIRCUIT BREAKER OFF) you may find the protection devices that GE has in place. You may also
find the fuse or breaker hiding in there too! Good luck.
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
Range/oven breaker won't reset
it may be a wire fried or came loose, and is touching metal. if an exposed wire is touching metal, you wont be able to reset the breaker. pull the range out, and remove the back, and if necessary, lift the top and check the wires to the burners also. it should be easy to spot the wire that's causing the problem from there. let me know if you have further questions, shane
Sep 13, 2009 | Kitchen Ranges
Oven or smooth top will not turn on. breakers are good and it is plugged in.
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Dec 04, 2007 | Magic Chef CER3725AA Electric Kitchen...
Frigidaire FEF366 Electric Kitchen Range Logo
177 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
