Re: the Phone line is loaded when connected to the RE-1
Try calling linear;s tech service support today and walk you through use a good 100 dollar multi-meter to check out going devices at dmarc and the device blessings friend!
4 important points or facts to note with chargers are as follows:
1. Supply voltage ~AC/Voltage (input, say 110Vac, 220Vac)
2. Output voltage (VDC)
3. Output ampere rating (amps)
4. Jack type for connecting charger to your phone.
What this implies is that you have to get your old phone to a store where phone chargers are sold or can be purchased (because of the connector jack)
However, you need to know the specific OUTPUT charging voltage (indicated as DC) and current for your phone
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
How are you checking the batteries? If you are simply reading the voltage with a multimeter, then this is probably your issue. The batteries, when getting worn out, will often show full voltage in a static (non-loaded) state, but as soon as they are called on to produce load, their voltage will drop significantly, thus giving the DC bus low indication. Batteries in UPS's are similar to car batteries, they need to be tested under load to ensure they are good. If they are three years old or older, chances are they need to be replaced.
Pin
Name
Color
Description
3.3V
Orange
+3.3 VDC
3.3V
Orange
+3.3 VDC
COM
Black
Ground
5V
Red
+5 VDC
5
COM
Black
Ground
6
5V
Red
+5 VDC
7
COM
Black
Ground
8
PWR_OK
Gray
Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok)
9
5VSB
Purple
+5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec)
10
12V
Yellow
+12 VDC
11
12V
Yellow
+12 VDC
12
3.3V
Orange
+3.3 VDC
13
3.3V
Orange
+3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V).
14
-12V
Blue
-12 VDC
15
COM
Black
Ground
16
/PS_ON
Green
Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
17
COM
Black
Ground
18
COM
Black
Ground
19
COM
Black
Ground
20
-5V
White
-5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units)
21
+5V
Red
+5 VDC
22
+5V
Red
+5 VDC
23
+5V
Red
+5 VDC
24
COM
Black
Ground
/PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
With everything connected and the engine running, you should see a charging voltage of about 13.5 ~ 15 VDC on the battery terminals. Engine off and and lights / or some other load on the battery should show around 12.5 VDC.
If the 14 ~ 15 VDC charge voltage is present when running, and the battery fails to start the engine; it could indicate a poor connection at the battery posts, dead or failing cell(s) or failing starter.
Have a look at the video below - even though it's about cars charging systems, it applies. Good luck!
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Description:Power supply remote signal not connected The control signal cable for the ON/OFF control of the 24/38-VDC output is disconnected. The signal wire grounded inside the power supply unit has been pulled up by the IP PCB to detect the level.
Code: 003 S97
Description:38-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 38-VDC resistance inside the power supply unit. The detection level is approximately 18 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
Code: 004 S97
Description:24-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 24-VDC resistance inside the power supply unit. The detection level is approximately 11 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
Code: 006 S97
Description:3.3-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 3.3-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
Code: 007 S97
Description:1.8-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 1.8-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
Code: 008 S96
Description:Control panel not connected The absence of the control panel unit to be connected to the MC PCB is detected. Since this configuration lacks this panel, this error indication will not be issued under normal operating circumstances.
Code: 009 S96
Description:Print counter not connected The absence of a print counter is detected.
Code: 011 S96
Description:CIS PCB not connected The connection of the CIS PCB cannot be confirmed.
1) if there no diallling tone test a) battery with VOM, clean the contacts batteries with ethylic alcohol with cotton swab. b) test the antenna is o.k or replace 2) the voltage line will be 48 Vdc , you must test it. use another phone that you know is working fine. 3) if the another phone work the line is the problem call to the company 4) if work replace the batte or antenaa or the phone completely. God bless you
