Question about Motherboards
Linux installation motherboard 945 intel chipset foxconhdd 120gb sata problem is linux not installed in sata hddpls sugest.................
  • 118 Answers
Re: linux installation
If your hard disk is sata follow these steps
1. restart your computer and press del key or F2 to enter into bios
2. Go to drive configuration and change the sata ATA/IDE mode to Legacy
3. press F10 to save the settings
Install Linux and you are done
good luck
Posted on Nov 22, 2007
0 characters
3 Points
Cant detect sata
Hello you maybe need a driver you can download it here:
Try the one for the chipset.
Maybe the harddrive/or cable has a fault. Does the drive spinning
when the power is on ??
Check the bios for the settings for the harddrive
(press delete when you boot)
More info here:
Good luck
Nov 18, 2012 | Intel D945GNT Motherboard
Dear sir, Audio drivers are not install my pc
Hi, download your audio drivers from Intel site
select your operating system form the box in the left and click drivers on the right box, just below there will be drivers shown for your motherboard.
Mar 07, 2011 | Intel D945GCNL Motherboard
Connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
May 04, 2010 | Intel 845GE Motherboard
Linux driver motherboard choice your intel 945 chip driver for lenux ,may be install lenux fadora 10 its take auto istall all hardware componets driver
Oct 22, 2009 | Mercury P4VM800M7 Motherboard
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
945 motherboard
hi while installing drivers u have to go in vga option in that some files are there u have to install
Dec 23, 2008 | Intel D945GCZ Motherboard
Can u assist me, i hav motherboard but there s no name in that how can i find it, the only thing i found in the board is 945-15D2
it is 945 chipset using intel chips or may be made by intel but it will use the drivers of 945 chipset
Nov 19, 2008 | Intel D945GCL Motherboard
Need network drivers
1st of all r u using onboard lan?
n r u using desktop or server pc?
if u want something so u'ave to know what u actually want n give abit brief information abut it!
download the driver from this site if its not working so then wait to intel coz they havent made drivers of ur lan for linux yet!
Nov 05, 2007 | Intel Motherboard
Motherboards Logo
637 people viewed this question
Top Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Motherboard Expert? Answer questions, earn points and help others
