Question about Hyundai ImageQuest Q17 17" LCD Monitor
Hyundai ImageQuest Q17 shifting pixels
Can anyone give me a tip how to solve the following problem I have since short with my Hyundai ImageQuest Q17 flat screen display.
The pixel in the displayed screens shifting and jittering right to left and back ,causing a scambled display with horizontal lines.
The scrambling of pixels differs between screens, but I cannot get it back to normal.
Any help and/or tip is wecome.
Thanks in advance.
Wim Steenhuis
  • Marrv Jun 06, 2008
    exactly the same problem being suffered here. I have checked gfx cards not overheating & reseated everything to eliminate anything else. any suggestions on how to improve it?
4 Suggested Answers
SOURCE: Monitors goes black - Hyundai Q17
Thanks. I sent the monitor to Hyundai as it was under guarantee. After a 3-months-wait (!!) it came back with a new bulb.
Thanks !
Posted on Oct 31, 2007
  • 4 Answers
SOURCE: Speaker in screen dosen't work
a normal minijack (3,5 mm) cable, with the same plug in both ends.
if you have a cable already, try to adjust the volume using the buttons on the screen
Posted on Mar 10, 2009
  • 152 Answers
SOURCE: Hyundai imagequest Q17 montior problem
ontherhodes5, Your monitor will probably need servicing for one or both power supplys in the unit. Yes, If you can get a new oem Switch-mode-power-supply/inverter board you might get it working. I suspect that it (smps) can't supply the voltages needed by the logic-interface board- therefore no digital data can be processed for display on the screen, which should be white-bright but now only gray. (dim) because the 1000v ac from inverter circuit is also missing 10to40% of it's output. Your best bet will be to find out if Hundai can do a repair/swapout. You send yours+$40 to $90 and they send you a Refurbished same model with new CCF tubes, Inverter board, smps board. It seems that sooner or later these lcd ccf (cold cathode fluorescent tube backlights) will need servicing. Don't feel bad about this monitor. There are about, (guess only) 2500 more of all makes and models with similar power supply problems out there. To see whats inside a lcd search YOUTUBE for vids of servicing or repair of lcd screens or similar.. also www badcaps.net ??? or lcdrepair.us or visit electronicrepairguide.com run by a Jestine Yong. Ignore the sales pitch and just look fyi. hope this was of some help. drop me a note if possible. I'm louie12fix on fixya or lmistyrel@ aol.com BYE
Posted on Mar 30, 2009
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
I have tried playing my PS3 through my Imagequest Q17+ monitor by way of an HDMI to DVI/D adaptor but the monitor says incompatible signal. I am unsure if the adaptor i have is faulty or if this will work...
I have always had good luck with DVI to HDMI converters. My advice would be to find another monitor and see if it works on that. If it does, then you know the signal is getting through. It might be a setting on the PS3 as well. I'm only familiar with PC to monitor conversion.
Jan 19, 2018 | Hyundai ImageQuest Q17 17" LCD Monitor
I have pushed the screen down and i can't get it back up. Please help
Open the case of the monitor and reseat the lcd panel. Beware, it's very fragile and cannot be repaired.
Nov 25, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Monitor comes on for a few seconds then off. Turn it off then back on and does the same thing.
try your colour reduce it a bit and it should work if there is to much colour it will turn on and off
Jul 02, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Mar 29, 2009 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Mar 10, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Screen does not start (switch on)
Sounds like a mode issue. Make sure you have the pc set to a compatible mode for the monitor. You may also want to double check the vga cable is firmly set in the monitor and pc.
Aug 22, 2008 | Hyundai ImageQuest Q17 17" LCD Monitor
Looking for LCD Screen
I'd like to find one, myself. Ours has about a 20 pixel vertical band from top to bottom dead center in the screen. What is wrong with yours?
Jul 08, 2007 | Hyundai ImageQuest HQL320WR 32 in....
I had the same problem some time ago.
After dismateling the power-supply unit it apeared that there was en crack in a solderjoint at one of the power transistors. This transistor has 3 legs (TO220 I believe), from which the middle leg had a solder crack, probebly due to thermal stress. Just resolder and it worked again....
Its worth a try I think.
Succes,  Wim Steenhuis.
Oct 04, 2006 | Hyundai ImageQuest Q17 17" LCD Monitor
Open Questions:
Hyundai ImageQuest Q17 17" LCD Monitor Logo
53 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
