I Have a RCA XL 100 Commercial skip TV I lost the original remote, but am able to use the Dish sattelite remote to control the channel ( not volume?) the V-chip is blocking random channels that I do not want blocked. It asks for a passcode to unlock but cannot without a remote to control the actual TV. Is there a way I can fix this to unlock my tv.
There is no other way to unlock it, without its original remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Gopakumar Gopalan Google
SOURCE: Commercial Skip Feature
When a commercial comes on, you press the "Commercial Skip" button on the remote. Then you see a 30-second countdown timer appear on the screen. If you think there will be more than 30-seconds of commercials, then press the button more (each time you press adds 30 seconds to the on-screen timer -- usually I press it 4 to 5 times). The timer stays counting down on the screen while you change channels during the commercials to see what else is on. When the timer counts down to 0, it is erased from the TV screen and the TV automatically changes you back to the channel it was on when you pressed the commercial skip button. I use this feature a lot! I wish all TV's had it built in. Some universal remotes have a similar (but more awkward feature) where the remote has the timer inside it, and it sends a signal back to the TV when the count is up, but I don't think this would work as well.
SOURCE: RCA XL100 Commercial Skip won't turn on
The power supply or one of the circuits that it is feeding has a short in it. It may be able to be serviced by someone who knows the product and is experienced at working on the model you have. There may be a question about parts availability for it.
You can call RCA to find out who the authorized service rep is for your area. This is something that most small TV service stores may not be able to repair.
Ask for an estimate before approving service. The repair for your unit may be expensive.
Jerry G.
SOURCE: Input
Use a RF Modulator. This will allow you to connect the dvd to the antenna jack of the tv.
SOURCE: Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
