Macbook pro, it was bought from a pawn shop. Now After 1 year it has a flash player problem, tho it says drivers are current. I tried to restore it to default setting but it is asking for administrator's password, some name who I don't know.. My question is, can I takeout the hard drive format it and put IOS with a pen drive. Will it work
This link explains your solution
OS How to erase and install
SOURCE: Macbook keeps restarting
all macbooks have a security that will not let you switch the harddrive from one the the other. Apple will need to reset the computer at an Apple store!!! His drive is DEAD!!!
SOURCE: USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
SOURCE: My MacBook pro is asking for a system lock pin how do I bypass it because I don't know the pin
You can reset your password with the OS disc. Reboot using the disc and choose Reset Password from the menu bar.
